NVIDIA G-SYNC displays deliver unparalleled 360 Hz gameplay, making them the choice for esports enthusiasts everywhere. Experience low system latency for faster reaction times, practically no ghosting, and smooth motion to help stay on target. Add in zero tearing with G-SYNC, and it's clear why these displays are designed to win.
Extremely fluid gameplay
Dedicated to competitive gamers, the 1ms GTG response time significantly reduces monitor blur occurrence, and the 360Hz displays powered by NVIDIA G-SYNC are 1.5x faster than conventional 240Hz displays and take full advantage of ultra-high frame rates in today's biggest game titles. -
NVIDIA Reflex Latency Analyzer: victory measured in milliseconds
NVIDIA Reflex Latency Analyzer delivers the ultimate competitive advantage. Step confidently into battle knowing your PC is performing at peak level with the Reflex Latency Analyzer which captures end-to-end system latency and delivers a precise measure of your PC's performance. -
See every moment at its clearest
Rapid IPS monitors deliver the biggest advancements in competitive gaming monitors - from Variable Refresh Rate with maximum refresh rate range (1-360 Hz) to a built-in esports mode with black levels for competitive play and the fastest Ultra Low Motion Blur mode up to 240 Hz.
- MSI Oculux NXG253R - LED monitor - Full HD (1080p) - 24.5"
- LED-backlit LCD monitor - 24.5"
- Energy Class
- Class F
- Power Consumption (On mode)
- 22 W
- Adaptive-Sync Technology
- NVIDIA G-SYNC Compatible
- 5-way joystick, USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 360 Hz, HDMI: 240 Hz)
- Pixel Pitch
- 0.2829 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 1 ms (grey-to-grey), 1 ms (MPRT)
- Gaming
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.01 cm x 23.37 cm x 39.93 cm
- 6.47 kg
- DisplayPort 1.4
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- Diagonal Size
- 24.5"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2829 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Refresh Rate
- 150.9 - 417.6 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Frameless bezel design, HDR Ready technology, Gaming Mode
- Black
- 56.01 cm x 23.37 cm x 39.93 cm - with stand
- 6.47 kg
Input
- 5-way joystick
- 2 x HDMI , DisplayPort , Headphones , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB cable , 1 x power cable , 1 x power adapter
- DisplayPort 1.4
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22 W
- Power Consumption SDR (On mode)
- 22 kWh/1000h
- Power Consumption HDR (On mode)
- 35 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 56.01 cm - depth: 6.43 cm - height: 33.55 cm
- Shipping Width
- 76.6 cm
- Shipping Depth
- 22.2 cm
- Shipping Height
- 43.5 cm
- Shipping Weight
- 9.02 kg
- Limited warranty - 3 years
