MSI NVIDIA GeForce GTX 1080 Ti 11GB GDDR5X Founders Edition
Quicklinx: CRP7WS00 Mfr#: GTX 1080 Ti Founders Edition
10: ULTIMATE GEFORCE®
GTX 1080 Ti
The GeForce® GTX 1080 Ti is NVIDIA’s new flagship gaming GPU, based on the NVIDIA Pascal™ architecture. The latest addition to the ultimate gaming platform, this card is packed with extreme gaming horsepower, next-gen 11 Gbps GDDR5X memory, and a massive 11 GB frame buffer.
DOMINANT PERFORMANCE
Discover unrivaled gaming, powered by NVIDIA Pascal™ - the world’s most advanced GPU architecture. GeForce GTX 1080 Ti features massive gaming horsepower with 3582 NVIDIA® CUDA® cores and 12 billion transistors. This means you can count on up to 3X the performance of previous-generation graphics cards, plus breakthrough gaming technologies and VR experiences.
NEXT-GEN GAMING TECHNOLOGIES
Get all the power and performance you need to drive the latest displays, including VR, ultra-high-resolution, and multiple monitors.
NVIDIA GameWorks™ technologies give you the smoothest gameplay and cinematic experiences, as well as revolutionary 360-degree image capture – even in VR.
NEW LEVELS OF VR
The GeForce GTX 1080 Ti delivers truly next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets. It’s all driven by NVIDIA GameWorks™ technologies and brought to life and amazing VR audio, physics, and haptics.
OBSESSIVE CRAFTSMANSHIP
Unprecedented gaming horsepower. Exceptional craftsmanship. A 7-phase dualFET power supply. All cooled by a radial fan with an advanced vapor chamber designed to for consistent performance in even the most thermally challenging environments.
GEFORCE GTX 1080 Ti
This is the forward-thinking innovation that makes the GeForce 1080 Ti the Ultimate GeForce.
GPU Engine Specs:
NVIDIA CUDA® Cores - 3584
Base Clock (MHz) - 1480
Boost Clock (MHz) - 1582
Memory Spec:
Memory Speed - 11 Gbps
Standard Memory Config - 11 GB GDDR5X
Memory Interface Width - 352-Bit
Memory Bandwidth (GB/sec) - 484
Technology Support:
Simultaneous Multi-Projection
VR Ready
NVIDIA Ansel
NVIDIA SLI® Ready - SLI HB Bridge Supported
NVIDIA G-Sync™-Ready
NVIDIA GameStream™-Ready
NVIDIA GPU Boost™ 3.0
Microsoft DirectX 12 API with feature level 12_1
Vulkan API
OpenGL 4.5
Bus Support - PCIe 3.0
OS Certificates: Windows 7-10, Linux, FreeBSDx86
Display Support:
Maximum Digital Resolution - 7680x4320@60Hz
Standard Display Connectors - DP 1.4, HDMI 2.0b
Multi Monitor - Yes
HDCP 2.2
Graphics Card Dimensions:
Height 4.376"
Length 10.5"
Width 2 Slot
Thermal and Power Specs:
Maximum GPU Temperature (in C) 91
Graphics Card Power (W) 250 W
Recommended System Power(W) 600 W
Supplementary Power Connectors - 6-pin, 8-pin
  • Next-generation gaming technologies
    Get all the power and performance you need to drive displays, including VR, ultra-high-resolution, and multiple monitors. NVIDIA GameWorks technologies give you the smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture - even in VR.
  • Obsessive craftsmanship
    Unprecedented gaming horsepower. Exceptional craftsmanship. A 7-phase dualFET power supply. All cooled by a radial fan with an advanced vapor chamber designed for consistent performance in even thermally challenging environments.
  • Prepare for VR with MSI
    To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. MSI brings gamers an extremely realistic VR experience where games come alive.
MSI GTX 1080 TI - Founders Edition - graphics card - GF GTX 1080 Ti - 11 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
11 GB GDDR5X
Core Clock
1480 MHz
Boost Clock
1582 MHz
CUDA Cores
3584
Effective Memory Clock
11.01 GHz
Memory Interface
352-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4 cm x 26.6 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1480 MHz
Boost Clock
1582 MHz
CUDA Cores
3584
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia 2-way SLI ready, MSI Afterburner, NVIDIA Adaptive Vertical Sync, NVIDIA G-Sync ready, Nvidia GeForce GTX VR Ready, HDCP
Size
11 GB
GDDR5X SDRAM
Effective Clock Speed
11.01 GHz
Bus Width
352-bit
Required Power Supply
600 W
Additional Requirements
6-pin + 8-pin PCI Express power connectors
250 Watt
Software Included
MSI Afterburner
DisplayPort 1.4, HDCP 2.2
4 cm
26.6 cm
11.1 cm
1.06 kg
