GeForce® GTX 1060 GAMING X 3G
Core/Memory
• Boost Clock / Base Clock / Memory Frequency
1809 MHz / 1594 MHz / 8108 MHz (OC Mode)
1784 MHz / 1569 MHz / 8008 MHz (Gaming Mode)
1708 MHz / 1506 MHz / 8008 MHz (Silent Mode)
• 3072 MB GDDR5
Video Output Function
• DisplayPort x 3
• HDMI x 1
• Dual-link DVI-D x 1
• Virtual Reality Ready
• DirectX 12 Ready
• Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
THE LATEST GAMING TECHNOLOGIES
Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary new 360-degree image capture.
PERFORMANCE
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX™ 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
Torx 2.0 fan - teamwork for greater strength
Just like in games, the exclusive MSI Torx 2.0 fan technology uses the power of teamwork to allow the Twin Frozr VI to achieve another levels of cool. -
ZeroFrozr - stay undetected
ZeroFrozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans. -
Improved heatsink
Lurking under the cover of the GAMING graphics card is an engineering masterpiece, designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool and quiet gaming experience. -
Smooth heat pipes
Copper heat pipes with a smooth squared shape at the bottom maximize heat transfer from the surface of the copper base plate.
- MSI GTX 1060 GAMING X 3G - graphics card - GF GTX 1060 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 3 GB GDDR5
- Core Clock
- 1594 MHz
- Boost Clock
- 1809 MHz
- Effective Memory Clock
- 8.108 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.9 cm x 27.7 cm x 14 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1594 MHz
- Boost Clock
- 1809 MHz
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- MSI Solid Capacitor, Dual Fan Design, MSI Afterburner, 6 Phase PWM Design, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, NVIDIA G-Sync ready, NVIDIA GameWorks, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, Torx 2.0 Fans, Twin Frozr VI Thermal Design, HDCP
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.108 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- 120 Watt
- Included Accessories
- Backplate
- Software Included
- MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2 (1 year Premium licence), WTFast Gamers Private Network (2 months Premium licence)
- 3.9 cm
- 27.7 cm
- 14 cm
- 1.017 kg
