MSI NVIDIA GeForce GTX 1060 GAMING X 3GB GDDR5 PCIe3.0 Zero Froz
Quicklinx: CB7TWS00 Mfr#: GTX1060-GAMING-X-3G
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
GeForce® GTX 1060 GAMING X 3G
Core/Memory
• Boost Clock / Base Clock / Memory Frequency
1809 MHz / 1594 MHz / 8108 MHz (OC Mode)
1784 MHz / 1569 MHz / 8008 MHz (Gaming Mode)
1708 MHz / 1506 MHz / 8008 MHz (Silent Mode)
• 3072 MB GDDR5
Video Output Function
• DisplayPort x 3
• HDMI x 1
• Dual-link DVI-D x 1
• Virtual Reality Ready
• DirectX 12 Ready
• Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
THE LATEST GAMING TECHNOLOGIES
Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary new 360-degree image capture.
PERFORMANCE
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX™ 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
  • Torx 2.0 fan - teamwork for greater strength
    Just like in games, the exclusive MSI Torx 2.0 fan technology uses the power of teamwork to allow the Twin Frozr VI to achieve another levels of cool.
  • ZeroFrozr - stay undetected
    ZeroFrozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
  • Improved heatsink
    Lurking under the cover of the GAMING graphics card is an engineering masterpiece, designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool and quiet gaming experience.
  • Smooth heat pipes
    Copper heat pipes with a smooth squared shape at the bottom maximize heat transfer from the surface of the copper base plate.
MSI GTX 1060 GAMING X 3G - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060 - up to
3 GB GDDR5
Core Clock
1594 MHz
Boost Clock
1809 MHz
Effective Memory Clock
8.108 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.9 cm x 27.7 cm x 14 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1594 MHz
Boost Clock
1809 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
MSI Solid Capacitor, Dual Fan Design, MSI Afterburner, 6 Phase PWM Design, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, NVIDIA G-Sync ready, NVIDIA GameWorks, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, Torx 2.0 Fans, Twin Frozr VI Thermal Design, HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
8.108 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
120 Watt
Backplate
Software Included
MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2 (1 year Premium licence), WTFast Gamers Private Network (2 months Premium licence)
3.9 cm
27.7 cm
14 cm
1.017 kg
