MSI NVIDIA GeForce GTX 1060 3GT OC 3GB GDDR5 PCIe3.0 Dual Fan
Quicklinx: CB83WS00 Mfr#: GTX1060-3GT-OC
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
THE LATEST GAMING TECHNOLOGIES
Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary new 360-degree image capture.
PERFORMANCE
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX™ 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
  • VR-ready
    Discover advanced VR performance, low latency, and Plug-and-Play compatibility with headsets, driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment.
  • Advanced gaming technologies
    Pascal is built to meet the demands of various displays, including VR, Ultra HD, and multiple monitors. It features NVIDIA GameWorks technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes a 360-degree image capture.
  • Performance
    Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX 12 features to deliver fast, smooth and power-efficient gaming experiences.
  • Dual fans thermal design
    Dual fans cover more area of heatsink to take heat away more efficiently.
MSI GTX 1060 3GT OC - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
3 GB GDDR5
Core Clock
1544 MHz
Boost Clock
1759 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Monitors Supported
3
Interfaces Details
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.9 cm x 24.3 cm x 11.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1544 MHz
Boost Clock
1759 MHz
VR Ready
3
Interfaces Details
API Supported
Dual Fan Design, MSI Afterburner, Military Class 4 Components, Hi-C CAP, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
MIL-STD 810G
3.9 cm
24.3 cm
11.5 cm
556 g
