The MPG series brings out the best in gamers by allowing full expression in color with advanced RGB lighting control and synchronization. Experiment on another level of personalization with a front LED strip that provides convenient in-game and real time notifications. With the MPG series, transform your equipment into the center of attention and top leaderboards in style.
Curved Gaming
View more of your game. MSI Curved Gaming monitors are perfect for gamers to play their games. -
UWQHD (3440 x 1440)
Game titles will even look better, displaying more details due to the WQHD (3440 x 1440) resolution. -
1000R perfect curved screen
Perfectly fits the curvature of the human eye so that you can see the entire screen without any fatigue. -
Smart gaming
Pair with AI to create a new way of gaming. -
Rapid boost (165 + 1ms)
Experience smooth gaming with a blazing fast refresh rate and response time, that gives you the upper hand in fast moving games. -
HDR 1000
Provide eye-catching detail through contrast and shadows adjustment.
- MSI MPG ARTYMIS 343CQR - LED monitor - curved - 34" - HDR
- LED-backlit LCD monitor - 34"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/414510
- Energy Class
- Class G
- Power Consumption (On mode)
- 39.9 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium
- 5-way joystick, USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 (DisplayPort: 165 Hz, HDMI: 100 Hz, USB-C: 165 Hz)
- Pixel Pitch
- 0.23175 mm
- Brightness
- 550 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- HDR Capable
- DisplayHDR 400
- Response Time
- 4 ms (grey-to-grey), 1 ms (MPRT)
- Gaming
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100.9% Adobe RGB (CIE 1976), 102.7% NTSC (CIE 1976), 117.8% Rec 709 (CIE 1931), 117.8% Rec 709 (CIE 1976), 117.8% sRGB (CIE 1976), 121.8% sRGB (CIE 1931), 86.2% NTSC (CIE 1931), 89.8% DCI-P3 (CIE 1931), 90.2% Adobe RGB (CIE 1931), 93.8% DCI-P3 (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 79.53 cm x 31.56 cm x 42.25 cm
- 9.17 kg
- DisplayPort 1.4, HDCP 2.2, CIE1931, CIE1976
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 34"
- Curved Screen
- Yes (1000R)
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.23175 mm
- Brightness
- 550 cd/m²
- Contrast Ratio
- HDR Certification
- DisplayHDR 400
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 165 Hz
- Horizontal Refresh Rate
- 71.52 - 245.85 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture by picture, frameless, Crosshair Display, Picture-in-Picture, MSI Mystic Light, Gaming Mode, 10-bit(8-bit + FRC) Colour Depth
- Black
- 79.53 cm x 31.56 cm x 42.25 cm - with stand
- 9.17 kg
Input
- 5-way joystick
- DisplayPort 1.4 (HDCP 2.2) , 2 x HDMI (HDCP 2.2) , Headphones , USB-C , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-A to USB-B cable , 1 x HDMI cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 39.9 W
- Power Consumption SDR (On mode)
- 39.9 kWh/1000h
- Power Consumption HDR (On mode)
- 70 kWh/1000h
- Power Consumption (Typical)
- 54 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 79.53 cm - depth: 31.56 cm - height: 42.25 cm - weight: 9.17 kg , Without stand - width: 79.53 cm - depth: 16.31 cm - height: 36.55 cm
- Shipping Width
- 88.2 cm
- Shipping Depth
- 28 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 12.9 kg
