This PRO motherboard fits in any PC. Quality you can trust with outstanding performance and clever business solutions are key aspects of this motherboard. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO motherboard.
Outstanding memory performance and stability
MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability. -
Secure and reliable UEFI BIOS solution
This UEFI BIOS is completely rebuilt and features a plethora of advanced possibilities. From M-Flash for easy BIOS flashing to advanced data protection and system security, Click BIOS hands you the tools to fully protect and optimize the system. Through smart design Click BIOS is faster. By reducing the use of graphics in the UEFI shell, it boots faster, reacts faster and adds a smooth experience when changing settings. Smart categorizing of functions and settings make this the extremely easy BIOS. -
Humidity protection
Reduction in moisture absorption helps prevent "Conductive Anodic Filament". -
Circuit protection
Carefully selected materials, multiple PCB layers and shielding result in the optimal circuit protection for this MSI motherboard. -
ESD protection
Each and every I/O port is protected against the hazards of electro static discharge. -
Easy diagnostic
MSI EZ Debug LED is an easy troubleshooting tool using 3 LEDs to indicate CPU / Memory / VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the source of your problem and get back into operation quickly. -
Enhanced CPU overvoltage protection
Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. An LED near the 24 pin CPU power connector let you know that overvoltage protection is activated for easier troubleshooting. -
VGA Armor - reinforced PCI Express slot
Meet VGA Armor, strengthened PCI Express slots using more solder points to make sure you never have to worry about breaking off any of the slots. -
Total Fan Control
Total Fan Control gives you complete control of all your fans connected to the motherboard, through an advanced and easy to use interface. -
Studio grade sound with Audio Boost
Audio Boost delivers the extremely high sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 6-channel audio or high impendence headphones and truly dominate the game. -
2x front USB 3.1 Gen1
With a clever placed USB 3.1 Gen1 front pin header, available on this MSI motherboard, you can connect up to 2 USB 3.1 Gen1 devices directly to the front of your PC Chassis. This way you can easily enjoy fast USB speeds without having to use the hard-to-reach USB ports on the rear. -
Legacy DVI / VGA video support
To support professional monitors, TV's, beamers and other displays, this MSI motherboard features DVI and a VGA video output. No matter what screen type you want to connect, using a dedicated graphics card or an onboard connector, MSI motherboard have you covered. -
Be sure to take full advantage by connecting your devices to the optimized ports.
- MSI H110M PRO-VD - motherboard - micro ATX - LGA1151 Socket - H110
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel H110 Express
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600
- USB / FireWire Ports
- 2 x USB 3.1 Gen 1 + 4 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA
- 1 x DVI-D , 4 x USB 2.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 2 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet)
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- MSI ClickBIOS, UEFI BIOS
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, MSI Military Class IV, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI VGA Armor, Intel Small Business Basics support, overvoltage protection
- Software Included
- MSI M-Cloud
- 23.5 cm
- 18 cm
MSI H110M PRO-VD Intel S1151 DDR4 USB3.0 PCIe SATA3 uATX
