Product
Brand
MSI GT72S Skylake i7-6820HK 32GB 1TB + 512GB SSD 17.3" Win 10
Quicklinx: BVHGWS00 Mfr#: 9S7-178211-612
  • Core i7
  • IEEE 802.11n
  • NVIDIA GeForce GTX 980M
  • BD-Writer
MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system. MSI True Color technology guarantees that each panel in MSI notebook provides fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications. Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays. MSI gaming notebook built in high quality wide-view angle display takes image clarity to a high level with higher pixel resolution. Images are more sharp and vivid in contrast level and clearer in brightness level. Hence, images are more vivid even from left and right side of the viewing angle. When you're playing games, you will have breathtaking and brilliantly true-to-life viewing experience.
Push the limits of your audio peripherals and hear the difference with the SABRE audio DAC. Discover details that you've been missing or maintain the upper-hand in competitive FPS matches where every bit of sound counts. Originally developed for military fighter jets, Nahimic specializes in 3D sound software processing and audio improvements offering virtual 7.1 sound in immersive high definition. Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. The GT72 is packing advanced Dynaudio design with 2 channels with 1 subwoofer, and its absolutely authentic hearing experience. People who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect.
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions. Stop losing games to lag with Killer DoubleShot Pro. Protect and prioritize networking traffic while preventing lag spikes so you can game without fear and play at your best. Select programs you want your network to prioritize to ensure maximum bandwidth and track your speeds. Killer DoubleShot Pro supports both Killer Gb LAN and Wi-Fi 802.11ac dual band protocol and improves average latency.
MSI GT72S 6QE 612UK Dominator Pro G - 17.3" - Core i7 6820HK - 32 GB RAM - 256 GB SSD (2x) + 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (6th Gen) 6820HK / 2.7 GHz (3.6 GHz) / 8 MB Cache
32 GB DDR4 (2 x 16 GB)
Storage
2 x 256 GB - M.2 SSD Super RAID 4, NVMe + 1 TB HDD / 7200 rpm
Optical Drive
Blu-ray Writer
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce GTX 980M - 8 GB GDDR5
Keyboard Backlight
Integrated Webcam
802.11b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
9-cell
Matte black, brushed metal
42.8 cm x 29.4 cm x 4.8 cm
3.78 kg
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Mobile Intel CM236 Express
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
32 GB (2 x 16 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000 - 2133 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
2 x 256 GB SSD - (M.2) PCIe - MSI Super RAID 4, NVM Express (NVMe)
Secondary Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
RAID Level
RAID 0
Optical Drive
BD-Writer
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, WideView, MSI Matrix Display, NVIDIA G-SYNC, MSI True Colour Technology
Audio & Video
Graphics Processor
NVIDIA GeForce GTX 980M - 8 GB GDDR5 SDRAM
Camera
Yes - 1080p
Sound
Stereo speakers, subwoofer, microphone
Audio Features
Dynaudio Premium Sound Technology, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
Keyboard, touchpad
Keyboard Backlight
SteelSeries Engine technology, SteelSeries Full Color
Communications
Wireless
Wireless Controller
M.2 Card
Network Interface
Gigabit Ethernet
Killer DoubleShot Pro Technology, Smart Teaming, Killer Shield, Advanced Stream Detect 2.0
9-cell
AC Adapter
Output
230 Watt
Connections & Expansion
LAN , Microphone input , Headphone output , 6 x USB 3.0 , HDMI , Mini DisplayPort , Audio line-in , Audio line-out , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
SteelSeries Engine, XSplit Gamecaster 2 (1 year Premium licence)
SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
3.78 kg
BVHG C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BVHG C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.07
BVHG C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
BVHG C2G 10m Select High Speed HDMI with Ethernet In Stock £32.58
BVHG C2G 15m Select High Speed HDMI with Ethernet In Stock £43.69
BVHG C2G Pro HDMI to VGA Converter In Stock £49.56
BVHG C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
