Get in the game before everyone else with Super RAID 4, MSI's fastest RAID 0 storage configuration. Combining dual PCI-E Gen 3.0 x4 SSD's utilizing NVMe technology, harness the full performance potential of the Gen 3.0 SSD through the optimization of the hardware and software outputting extreme read speeds over 3300 MB/s. Load games works in seconds. Whatever you need, you can get it done with just one Super Port. Transfer massive files faster than ever with up to 1000 MB/s transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home. Heat is the most original element on earth. It's pure physics that more energy will generate more heat. Cooling is therefore a knotty task to tackle with. MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU.
See gaming differently with breakthrough NVIDIA G-SYNC display technology. By synchronizing the display refresh rates to the GPU, G-GYNC eliminates screen tearing and minimizes stutter and input lag to deliver the very best gaming experience. Objects look sharper and gameplay is fluid and responsive to give you a serious competitive edge. MSI True Color Technology guarantees that each panel in a MSI notebook comes with the finest precision in color. After examination and an extensive factory calibration process by the MSI True Color Technology, the panel quality will be more accurate, close to 100% sRGB. Hence, each color is delivered with the highest standard precision in detail, guaranteeing excellent color fidelity for many use applications. Originally developed for military fighter jets, Nahimic specializes in 3D sound software processing and audio improvements offering virtual 7.1 sound in immersive high definition. Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. By utilizing dedicated headset amplifiers, an isolated audio board and gold-plated audio jacks, Audio Boost 2 delivers the most advanced listening experience of any gaming notebook. Audio performance is improved by an average of 30%, calculation based on measurable parameters in traditional audio solutions. Audio Boost 2 provides gamers a more detailed aural picture of their surroundings, helping in-game, while also minimizing distortion and providing a powerful amplifier which has no trouble powering even the most demanding gaming headsets. Gold-plated jacks will give you less noise interference and ensure the long-term durability of the jack.
Load games in seconds
Get in the game before everyone else with Super RAID 4, MSI's fastest RAID 0 storage configuration. Combining dual PCI-E Gen 3.0 x4 SSD's utilizing NVMe technology, harness the full performance potential of the Gen 3.0 SSD through the optimization of the hardware and software outputting extreme read speeds over 3300 MB/s. Load games works in seconds. -
Super Port - one port for everything
Whatever you need, you can get it done with just one Super Port. Transfer massive files faster than ever with up to 1000MB/s transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home. -
Cooler Boost 3
Heat is the most original element on earth. It's pure physics that more energy will generate more heat. Cooling is therefore a knotty task to tackle with. MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system, making the cooling design of GT72 the highest level of its kind. -
Architecture DDR4-2133 memory support
Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving over 2.9 GB/s in reading speed and 3.2 GB/s in writing. With over 30% faster performance than previous generations DDR3-1600, DDR4-2133 is the laptop standard to take your extreme gaming experience to the next level. -
NVIDIA G-SYNC
See gaming differently with breakthrough NVIDIA G-SYNC display technology. By synchronizing the display refresh rates to the GPU, G-GYNC eliminates screen tearing and minimizes stutter and input lag to deliver the very best gaming experience. Objects look sharper and gameplay is fluid and responsive to give you a serious competitive edge. -
MSI True Color technology
MSI True Color technology guarantees that each panel in a MSI notebook comes with the finest precision in color. After examination and an extensive factory calibration process by the MSI True Color Technology, the panel quality will be more accurate, close to 100% sRGB. Hence, each color is delivered with the highest standard precision in detail, guaranteeing excellent color fidelity for many use applications. -
Matrix Display
Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays in full HD with the Surround View Mode of MSI Matrix Display technology. -
Nahimic virtual surround sound
Originally developed for military fighter jets, Nahimic specializes in 3D sound software processing and audio improvements offering virtual 7.1 sound in immersive high definition. Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound and is only available on MSI gaming laptops. -
Sound by Dynaudio
Cooperated with the world leading speaker company Dynaudio for years, the whole designed GT72 is packing the latest speakers design with 2 channels with 1 subwoofer, and its absolutely authentic hearing experience. The signal has been enhanced up to 50% sound detail and up to 10dB volume has been increased; people who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect. -
Audio Boost 2
By utilizing dedicated headset amplifiers, an isolated audio board and gold-plated audio jacks, Audio Boost 2 delivers the most advanced listening experience of any gaming notebook. Audio performance is improved by an average of 30%, calculation based on measurable parameters in traditional audio solutions. Audio Boost 2 provides gamers a more detailed aural picture of their surroundings, helping in-game, while also minimizing distortion and providing a powerful amplifier which has no trouble powering even the most demanding gaming headsets. Gold-plated jacks will give you less noise interference and ensure the long-term durability of the jack. -
Killer DoubleShot Pro protecting your ping
Stop losing games to lag with Killer DoubleShot Pro. Protect and prioritize networking traffic while preventing lag spikes so you can game without fear and play at your best. Select programs you want your network to prioritize to ensure maximum bandwidth and track your speeds with the easy-to-use Killer Networking Manager. Killer DoubleShot Pro supports both Killer Gb LAN and WiFi 802.11ac dual band protocol and improves average latency by 3.5 times compared with those utilizing 802.11ac.
- MSI GT72S 6QE 044UK Dominator Pro G - 17.3" - Intel Core i7 6820HK - 16 GB RAM - 128 GB SSD x 2 + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) 6820HK / 2.7 GHz (3.6 GHz) / 8 MB Cache
- Memory
- 16 GB DDR4
- Storage
- 1.256 TB: 2 x 128 GB SSD - Super RAID 4 + 1 TB HDD
- Optical Drive
- Blu-ray Writer
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 980M
- Video Memory
- 8 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 9-cell
- Matte black, brushed metal
- 42.8 cm x 29.4 cm x 4.8 cm
- 3.78 kg
- Limited warranty - 2 years - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
Storage
- Total Capacity
- 1.256 TB
- Main Storage
- 2 x 128 GB SSD M.2 PCIe - MSI Super RAID 4
- Secondary Storage
- 1 TB HDD SATA 6Gb/s
- RAID Level
- RAID 0
- Optical Drive
- BD-Writer
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- WideView, MSI Matrix Display, NVIDIA G-SYNC compatible, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 8 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost 2, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
- Keyboard, touchpad
- SteelSeries Engine technology, SteelSeries Full Color
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Killer DoubleShot Pro Technology, Smart Teaming
- Technology
- 9-cell
AC Adapter
- Output
- 230 Watt
Connections & Expansion
- LAN , Microphone input , Headphone output , 6 x USB 3.0 , HDMI , Mini DisplayPort , Audio line-in , Audio line-out , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- SteelSeries Engine, XSplit Gamecaster 2 (1 year Premium licence)
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 3.78 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
