MSI GT72 6QD-048UK i7-6700HQ 2x8GB 128SSD GTX970M-6GB 17.3"
Quicklinx: BNNGWS00 Mfr#: 9S7-178211-048
  • Core i7
  • IEEE 802.11n
  • NVIDIA GeForce GTX 970M
Get the optimal performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high speeds in reading and writing. With fast performance this laptop takes your to extreme gaming experience. See gaming differently with breakthrough NVIDIA G-SYNC display technology. By synchronizing the display refresh rates to the GPU, G-GYNC eliminates screen tearing and minimizes stutter and input lag to deliver advanced gaming experience. Objects look sharper and gameplay is fluid and responsive to give you a serious competitive edge. MSI True Color technology guarantees that each panel in a MSI notebook comes with fine precision in color. Each color is delivered with high precision in detail, guaranteeing excellent color fidelity for many use applications.
  • One port for everything
    Transfer massive files faster than ever with high transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home.
  • Cooler Boost 3
    MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system, making the cooling design of GT72 optimal.
  • DDR4-2133 memory support
    Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high speeds in reading and writing.
  • NVIDIA G-SYNC
    See gaming differently with NVIDIA G-SYNC display technology. By synchronizing the display refresh rates to the GPU, G-GYNC eliminates screen tearing and minimizes stutter and input lag to deliver advanced gaming experience. Objects look sharper and gameplay is fluid and responsive to give you a serious competitive edge.
  • True Color technology
    MSI True Color technology guarantees that each panel in a MSI notebook comes with a fine precision in color. Each color is delivered with the high precision in detail, guaranteeing excellent color fidelity for many use applications.
  • True Color Profile
    Besides Gaming mode, True Color technology offers advanced color accuracy for several scenarios. Work or play, you can easily switch to the mode that suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere.
  • Matrix Display
    Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays in Full HD with the Surround View mode of MSI Matrix Display technology.
  • Nahimic Surround Sound
    Designed to work with audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound.
  • A keyboard all gamers desire for
    Every hardware detail of this keyboard is calculated and designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions.
  • Killer DoubleShot Pro
    Stop losing games to lag with Killer DoubleShot Pro. Protect and prioritize networking traffic while preventing lag spikes so you can game without fear. Select programs you want your network to prioritize to ensure high bandwidth and track your speeds with the easy-to-use Killer Networking Manager.
MSI GT72 6QD 048UK Dominator G - 17.3" - Intel Core i7 6700HQ - 16 GB RAM - 128 GB SSD + 1 TB HDD
Notebook
Operating System
Windows 10 Home
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
128 GB SSD + 1 TB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
3 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
9-cell
42.8 cm x 29.4 cm x 4.8 cm
3.78 kg
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
128 GB SSD M.2 PCIe
Secondary Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, WideView, MSI Matrix Display, NVIDIA G-SYNC compatible, MSI True Colour Technology
Audio & Video
Graphics Processor
Video Memory
3 GB GDDR5 SDRAM
Camera
Yes - 1080p
Sound
Stereo speakers, subwoofer, microphone
Audio Features
Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
Keyboard, touchpad
Keyboard Backlight
SteelSeries Full Color
Communications
Wireless
Network Interface
Gigabit Ethernet
Killer DoubleShot Pro Technology, Smart Teaming, Killer Shield
9-cell Lithium Ion
83 Wh
AC Adapter
Output
230 Watt, 19.5 V
Connections & Expansion
LAN , Microphone input , Headphone output , 6 x USB 3.0 , HDMI , Mini DisplayPort , Audio line-out , Audio line-in , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
MSI BurnRecovery, Norton Online Backup (30 days trial), Norton Internet Security (60 days trial), MSI Battery Calibration, Skype (Metro UI), Fresh Paint (Metro UI), Norton Anti-Theft (30 days trial), EverNote (Metro UI), Microsoft Office 2013 (30 days trial), MSI Boot Configure, MSI Dragon Gaming Center, Bewise CookBook (Metro UI), Green Field Puzzle (Metro UI), Hit Hot TuMetro (Metro UI), Corel Winzip, MSI System Control Manager, Norton Studio (Metro UI), MSI Super Charger, WildTangent Game App (Metro UI), Microsoft Essential 2012, Microsoft Wordament (Metro UI), Microsoft Game Pack (Metro UI), MAGIX Music Maker Silver
SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
3.78 kg
