The MSI GS66 Stealth 15.6" Gaming Laptop is slim and lightweight, without compromising on great specs.
SHARPER IN CORE BLACK
The matte black and low-profile design of the all-new GS66 Stealth keeps true to the Stealth moniker, allowing you to blend in within any situation. The reinforced black metal chassis makes it more rigid perfect for daily use. The GS66 Stealth is not only a powerful portable gaming laptop but it’s an essential tool that delivers an understated confidence within the gaming and professional world.
POWERFUL GAMING
Equipped with 10th gen Core™ i7 processor and NVIDIA GeForce RTX 2070 graphics with Max-Q design, the MSI GS66 Stealth offers faster load times and the ability of running the most complex applications. For unbelievably realistic lighting, shadows and reflections, the Turing architecture provides real-time ray tracing and AI-enhanced graphics.
MSI EXCLUSIVE COOLING TECHNOLOGY
To unleash the full potential of MSI GS66 Stealth, the new exclusive Cooler Boost Trinity+ with 0.1 mm thin blades to maximize airflow. The 3 fans drive the heat out through 7 heat pipes, which ensure the laptop keep cool and provides the best gaming experience.
BLAZE THROUGH THE GAME
The Full HD screen brings every detail to life, while a fast 240 Hz refresh rate helps to eliminate motion blur. You'll be able to see every detail, even during fast action scenes. Even the most turbo-charged racing games will look butter-smooth with no lag in gameplay.
STEELSERIES RGB BACKLIT KEYBOARD
With RGB lighting that can be adjusted on each key, you can add a personal touch to your gaming. Select the lighting scheme of your choice, and have your keyboard lit by millions of different colours.
