GS60 6QE GHOST PRO gaming notebook features MSI special Cooler Boost 3 technology, which creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A total of 4 heat pipes and dual fans actively and effectively push heat out of the system. The featured MSI SHIFT technology pushes the system to the extreme while minimizing noise and temperature. Switch between three profiles - Sport, Comfort, and Green to reach balance between system performance and comfortable user experience. The specialty of this notebook is the Super Port - one port for everything. Whatever you need, you can get it done with just this port. Transfer massive files faster, get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on the go or at home.
Cooler boost 3 - keep calm under pressure
Heat is the most original element on earth. It's pure physics that more energy will generate more heat. Cooling is therefore a knotty task to tackle with. MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A total of 4 heat pipes and dual fans actively and effectively push heat out of the system. -
SHIFT - boost performance under controlled noise & temperature
The special MSI SHIFT technology pushes the system to the extreme while minimizing noise and temperature. Switch between three profiles - Sport, Comfort, and Green to reach balance between system performance and comfortable user experience. -
Whatever you need, you can get it done with just one Super Port. Transfer massive files faster, get more pixel power supporting dual 4K displays and extend your field of view with daisy-chain capabilities. Even charge your phone or tablet faster on-the-go or at home. -
True Color technology
MSI True Color technology ensures that each panel in a MSI notebook comes with the extremely fine precision in color. Each color is delivered with precision in detail, providing excellent color fidelity for many applications. -
Matrix Display technology
Expand the vision for extreme gaming experience. MSI's Matrix Display supports up to 3 external displays simultaneously. Multitasking is made possible even during competitive gameplays. Connect the laptop to HDTV display, Matrix Display supports 4K output. MSI Matrix Display technology creates an ideal environment for extreme gaming experience and pleasant multimedia entertainment. -
Nahimic virtual surround sound - military technology, the next gaming standard
Originally developed for military fighter jets, Nahimic specializes in 3D sound improvements offering virtual 7.1 sound in immersive high definition. Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high-definition audio recorder to easily capture and stream studio-quality sound. -
Audio Boost
The MSI Audio Boost design enhances the output sound detail and sound stage. The gold flash audio jack provides stable sound transmission (reduced obstruction) and is characterized by low noise and low distortion, to greatly enhance headphone performance and faithfully reproduce each acoustic detail. -
The real deal: a keyboard all gamers desire for
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. More responsive and with tactile feedback, optimum WASD zone and support of multikey inputs allow you to gain full command over gaming missions.
- MSI GS60 6QE 093UK Ghost Pro - 15.6" - Intel Core i7 - 6700HQ - 16 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 128 GB SSD - NVMe + 1 TB HDD / 7200 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 970M
- Video Memory
- 3 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 6-cell
- 39 cm x 26.6 cm x 1.99 cm
- 1.9 kg
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 128 GB SSD M.2 - NVM Express (NVMe)
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare, WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
- Keyboard, touchpad
- SteelSeries Engine technology, SteelSeries Full Color
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Killer DoubleShot Pro Technology, Killer Shield
- Technology
- 6-cell
AC Adapter
- Output
- 150 Watt
Connections & Expansion
- Interfaces Details
- LAN , HDMI , Microphone input , Headphone output , USB-C , Mini DisplayPort , 2 x USB 3.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- SteelSeries Engine, XSplit Gamecaster 2 (1 year Premium licence)
- Case Material
- Aluminum
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 1.9 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
