MSI GF63 Thin 10SCXR Core i5 GTX1650 Max Q GDDR6 4GB 15.6"
Quicklinx: FV9DWS00 Mfr#: 9S7-16R412-426
  • Core i5
  • IEEE 802.11n
Sleek and powerful, whatever you want to play the MSI GF63 Thin 15.6" Gaming Laptop is waiting for you. Whether you're blasting through a mission in GTA 5 or editing photos, the latest 10th gen Intel® Core™ i5 CPU can keep up. With six-cores, multitasking is easy. Minimize a heavy game while you check your emails without the laptop freezing up.
POWERFUL GAMING
The NVIDIA GeForce® GTX 1650 is built with the breakthrough graphics performance of the award-winning NVIDIA Turing™ architecture. With performance that rivals the GeForce GTX 1060, it’s a blazing-fast supercharger for today’s most popular games, and even faster with modern titles.
THIN & LIGHT ALUMINUM HAIR-BRUSHED AESTHETICS
Only 1.86kg light and 21.7mm thin, the GF63 Thin has metallic top and keyboard cover paired with an unique X-shaped ventilation hidden underneath.
MSI EXCLUSIVE COOLING TECHNOLOGY
Fast processors and graphics cards generate a lot of heat. To keep them cool even with the most demanding games, the MSI Cooler Boost 5 technology planned dedicated thermal solutions for both the CPU and GPU with up to 6 heat pipes, work harmoniously by minimizing the heat and maximizing the airflow for smooth gaming performance in such compact chassis.
Silver lining print
Dreamed of a keyboard with enthusiastic lighting? Experience the SteelSeries silver-lining printing keyboard with intense red, that is also built to last.
  • Redefining what's possible
    The 10th Gen Intel Core i5 processor powers up with performance gains. Higher single-core frequency is better for gaming experience.
  • Thin, for the win
    NVIDIA Max-Q is an innovative approach to crafting the thinner, faster, quieter gaming laptop. It hits the sweet spot of advanced GeForce gaming and impossibly sleek design. Finally, a gaming laptop you can put on your lap.
  • Stay cool and quiet under load
    Fine-tuned to be noticeably quieter and cooler under load, easily blending into any environment.
  • Outstanding speed and clarity
    60 Hz IPS-level thin-bezel gaming display. The faster gaming display brings you more vibrant visuals so you never miss a beat.
  • Long battery life
    All juiced up for unplugged productivity and entertainment.
  • The way music should be
    Immerse yourself in lossless music and enjoy the premium sound quality with hi-resolution audio. Experience and listen to audio the way it was intended.
MSI GF63 10SCXR 426UK Thin - 15.6" - Intel Core i5 - 10300H - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (10th Gen) - 10300H / 2.5 GHz, up to 4.5 GHz / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
15.6" LED backlight 1920 x 1080 / Full HD @ 60 Hz
Graphics
NVIDIA GeForce GTX 1650
Video Memory
4 GB GDDR6 SDRAM
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet
3-cell
35.9 cm x 25.4 cm x 2.17 cm
1.86 kg
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10300H / 2.5 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Intel HM470
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:9
Audio & Video
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Video System Features
Max-Q design
Camera
Yes - 720p
Frame Rate
30 frames per second
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Backlight
Red backlighting
Communications
Wireless
Network Interface
Gigabit Ethernet
3-cell lithium polymer
51 Wh
AC Adapter
Output
120 Watt
Connections & Expansion
Interfaces Details
USB-C 3.2 Gen 1 , 3 x USB 3.2 Gen 1 , HDMI , LAN , Microphone input , Headphone output
Power adapter
MIL-STD 810G
1.86 kg
Sustainability Information
TCO Certified
