MSI GeForce RTX 4090 VENTUS 3X E Graphics Card
Quicklinx: HX2WWS00 Mfr#: RTX 4090 VENTUS 3X E 24G OC
The MSI GeForce RTX 4090 VENTUS 3X E graphics card sets a new standard for gaming and professional performance. With a powerful NVIDIA GeForce RTX 4090 processor at its core, this card delivers high-quality graphics rendering and computational capabilities. The 24 GB of GDDR6X memory ensures smooth gameplay and efficient data handling for even the most demanding tasks.
Experience gaming like never before with support for DirectX 12 Ultimate and OpenGL 4.6, enabling stunning visual effects and ultra-realistic gaming environments. The card's support for 4K@120Hz through HDMI 2.1 ports offers a mesmerizing visual experience, perfect for hardcore gamers and professional creators alike.
Built to last, the MSI GeForce RTX 4090 VENTUS 3X E features a robust design with an anti-bending plate, metal backplate, and nickel-plated copper base, ensuring the card remains stable and durable over time. The inclusion of advanced cooling technologies, such as the triple fan design and Airflow Control technology, keeps the card cool, ensuring optimal performance during intense gaming sessions or heavy workloads.
  • Enhanced cooling
    The MSI GeForce RTX 4090 VENTUS 3X E features advanced cooling technologies including Airflow Control technology, Core Pipe, and triple fan design. These innovations ensure optimal thermal performance, keeping the card cool under heavy loads.
  • Next-gen gaming performance
    Equipped with NVIDIA's Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores, this graphics card delivers exceptional gaming performance. Experience stunning visuals with support for DirectX 12 Ultimate and OpenGL 4.6.
  • Superior memory
    With a 384-bit bus width and 24 GB of GDDR6X SDRAM, the card provides high-speed data transfer rates of 24 Gbps. This vast memory capacity and speed are perfect for demanding games and professional applications.
  • Ultra-high resolution support
    The card supports a maximum external resolution of 7680 x 4320, allowing for immersive gaming and productive multitasking on multiple displays. It supports up to 4 monitors, with HDMI 2.1 enabling 4K@120Hz for a breathtaking visual experience.
  • Durable build quality
    Durability is ensured with features like the anti-bending plate, metal backplate, and nickel-plated copper base. The inclusion of a graphics card holder further aids in maintaining the card's integrity over time.
MSI GeForce RTX 4090 VENTUS 3X E - graphics card - NVIDIA GeForce RTX 4090 - 24 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
24 GB GDDR6X
Memory Speed
24 Gbps
Boost Clock
2550 MHz
CUDA Cores
16384
Memory Interface
384-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort , 2 x HDMI (supports 4K@120Hz as specified in HDMI 2.1)
API Supported
DirectX 12 Ultimate, OpenGL 4.6
6.2 cm x 32.2 cm x 13.6 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2550 MHz
CUDA Cores
16384
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
NVIDIA G-Sync ready, NVIDIA Ada Lovelace GPU technology, Triple Fan Design, Torx 4.0 Fans, nickel plated copper base, Core Pipe, Airflow Control technology, metal backplate, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, Nvidia Studio, Nvidia Broadcast, NVIDIA Reflex, NVIDIA DLSS 3, Dual ball Bearing Fans, MSI Zero Frozr technology, DrMOS, Custom PCB, anti-bending plate, Optical Flow Accelerator, HDCP
Size
24 GB
GDDR6X SDRAM
Memory Speed
24 Gbps
Bus Width
384-bit
Required Power Supply
850 W
Additional Requirements
16 pin PCI Express power connector
450 Watt
Graphics card holder
Software Included
MSI Afterburner, MSI Center, GeForce Game Ready Drivers, NVIDIA Studio drivers
6.2 cm
32.2 cm
13.6 cm
1.675 kg
Shipping Weight
2.308 kg
