MSI GeForce RTX 4080 SUPER 16GB Expert Graphics card
Quicklinx: HVJDWS00 Mfr#: RTX 4080 SUPER 16G EXPERT
The MSI GEFORCE RTX 4080 SUPER 16G EXPERT redefines gaming performance and visual quality. With its NVIDIA GeForce RTX 4080 SUPER graphics processor and a massive 16 GB of GDDR6X SDRAM, this video card is engineered to deliver high-resolution gaming experiences. The inclusion of NVIDIA's technologies, such as DLSS 3, Ray Tracing, and Tensor Cores, enhances every aspect of gaming, from graphics to latency, ensuring a seamless and immersive experience.
Coupled with the MSI Flow Frozr thermal design, which includes vapor chamber cooling, a dual fan setup, and a V-shape fin design, the card maintains optimal performance by efficiently dissipating heat. Whether you're a professional gamer or a creative professional, the MSI GEFORCE RTX 4080 SUPER 16G EXPERT offers the power, cooling, and features needed to push the limits of your gaming and creative projects.
  • Enhanced cooling
    The MSI GEFORCE RTX 4080 SUPER 16G EXPERT features the MSI Flow Frozr thermal design, incorporating vapor chamber cooling technology, V-shape fin design, and a dual fan setup. This cooling solution ensures optimal performance by efficiently dissipating heat, even under heavy loads.
  • Performance
    Equipped with NVIDIA GeForce RTX 4080 SUPER graphics processor and 10,240 CUDA cores, this video card delivers computing power. The boost clock speed of 2610 MHz, combined with 16 GB of GDDR6X SDRAM, provides the horsepower needed for high-resolution gaming, real-time ray tracing, and AI-enhanced graphics.
  • Gaming features
    Experience gaming technologies with NVIDIA DLSS 3, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores. These features, along with NVIDIA G-Sync readiness and Reflex, offer a smooth, immersive gaming experience with minimal latency and stunning visual fidelity.
MSI GEFORCE RTX 4080 SUPER 16G EXPERT - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
16 GB GDDR6X
Memory Speed
23 Gbps
Boost Clock
2610 MHz
CUDA Cores
10240
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI (supports 4K@120Hz as specified in HDMI 2.1a)
API Supported
OpenGL 4.6, DirectX 12 Ultimate
6.1 cm x 31.2 cm x 14.1 cm
Package Type
Box
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2610 MHz
CUDA Cores
10240
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Dual Fan Design, Vapor chamber cooling technology, NVIDIA G-Sync ready, DrMOS, Nvidia Studio, NVIDIA Reflex, Core Pipe, V-shape fin design, Nvidia Broadcast, NVIDIA Ada Lovelace GPU technology, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, NVIDIA DLSS 3, Custom PCB, Optical Flow Accelerator, aluminium alloy frame, NVIDIA RTX Video Super Resolution, push pull airflow, MSI Flow Frozr thermal design, die casted aluminium alloy frame, metal mesh cover, HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
23 Gbps
Bus Width
256-bit
Required Power Supply
850 W
Additional Requirements
16 pin PCI Express power connector
320 Watt
Graphics card holder, 16-pin to 3x 8-pin cable adapter
Software Included
MSI Afterburner, NVIDIA Studio drivers, MSI Center, GeForce Game Ready Drivers
DisplayPort 1.4a
6.1 cm
31.2 cm
14.1 cm
1.909 kg
Shipping Weight
2.906 kg
Package Details
Box
