MSI GeForce RTX 4080 SUPER 16G VENTUS 3X OC Graphics Card
Quicklinx: HX2XWS00 Mfr#: RTX 4080 SUPER 16G VENTUS 3X O
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 4080 SUPER
Interface: PCI Express 4.0
£847.26 ex VAT
£1,016.71 inc VAT
The MSI GeForce RTX 4080 SUPER 16G VENTUS 3X OC graphics card is designed to deliver an exceptional gaming and creative experience. With its powerful NVIDIA GeForce RTX 4080 SUPER graphics processor and 16 GB of GDDR6X SDRAM, it offers performance for the high-definition games and creative tasks. The card supports DirectX 12 Ultimate and OpenGL 4.6, ensuring compatibility with a wide range of applications and games. Its advanced cooling system, featuring Airflow Control technology and Torx 4.0 Fans, keeps the card running at optimal temperatures. Additionally, the inclusion of NVIDIA's technologies like DLSS 3, Ray Tracing, and Reflex, enhances gameplay with realistic graphics and responsive performance. Whether you're a gamer seeking smooth, immersive experiences or a creator needing powerful graphics processing, the MSI GeForce RTX 4080 SUPER 16G VENTUS 3X OC is engineered to meet expectations.
  • Enhanced cooling
    The GeForce RTX 4080 SUPER 16G VENTUS 3X OC features Airflow Control technology, Core Pipe, Dual ball Bearing Fans, and Torx 4.0 Fans, ensuring superior cooling performance that keeps the system running smoothly even under heavy loads.
  • Advanced gaming technologies
    Equipped with 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, and NVIDIA DLSS 3, this graphics card delivers a highly realistic and efficient gaming experience, enhancing every detail for immersive gameplay.
  • High-quality build
    With its anti-bending plate, metal backplate, and nickel-plated copper base, the MSI GeForce RTX 4080 SUPER 16G VENTUS 3X OC is designed for durability, ensuring a long-lasting and reliable performance for gamers and creators alike.
MSI GeForce RTX 4080 SUPER 16G VENTUS 3X OC - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
16 GB GDDR6X
Memory Speed
23 Gbps
Boost Clock
2580 MHz
CUDA Cores
10240
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort ¦ 2 x HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
6.2 cm x 32.2 cm x 13.6 cm
Package Type
Box
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2580 MHz
CUDA Cores
10240
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
NVIDIA G-Sync ready, Torx 4.0 Fans, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, Core Pipe, nickel plated copper base, Airflow Control technology, metal backplate, Nvidia Broadcast, Nvidia Studio, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, NVIDIA Reflex, Dual ball Bearing Fans, MSI Zero Frozr technology, DrMOS, fuse protection, anti-bending plate, Triple Fan Design, Metal Backplate with Thermal Pad, HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
23 Gbps
Bus Width
256-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
320 watt
Graphics card support bracket
Software Included
MSI Center, MSI Afterburner
DisplayPort 1.4a
6.2 cm
32.2 cm
13.6 cm
1.543 kg
Shipping Weight
2.147 kg
Package Details
Box
Brand: MSI
Price Range Ex VAT: £750 - £1000
