MSI Geforce RTX 4070 Ti SUPER 16G GAMING X SLIM Graphics Card
Quicklinx: HVJBWS00 Mfr#: RTX 4070 TI SUPER 16G GAMING X
The MSI Geforce RTX 4070 Ti SUPER 16G GAMING X SLIM video card is designed to meet the demands of serious gamers. With its 16 GB of GDDR6X memory, 2670 MHz boost clock, and support for DirectX 12 Ultimate and OpenGL 4.6, it delivers high performance and stunning visuals at resolutions up to 7680 x 4320. The card supports up to 4 monitors, making it perfect for immersive gaming setups. Advanced features like 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, and NVIDIA's suite of gaming technologies including DLSS 3, G-Sync, and Reflex, provide a competitive edge in both gaming and creative tasks. The TriFrozr 3 Thermal Design ensures your system stays cool, while the metal backplate and nickel plated copper heatpipes add durability and style. Whether you're gaming, streaming, or creating, the MSI Geforce RTX 4070 Ti SUPER 16G GAMING X SLIM is built to impress.
  • Enhanced cooling
    The MSI Geforce RTX 4070 Ti SUPER 16G GAMING X SLIM features the TriFrozr 3 Thermal Design, incorporating Torx 5.0 Fans, Core Pipe technology, and a triple fan design to ensure optimal cooling performance. This cooling system maintains your graphics card at low temperatures, even during intense gaming sessions, enhancing reliability and longevity.
  • High performance
    Equipped with 16 GB of GDDR6X SDRAM and a powerful NVIDIA GeForce RTX 4070 Ti SUPER graphics processor, this video card delivers high performance. With a boost clock speed of 2670 MHz and 8448 CUDA Cores, it provides smooth, high-resolution gaming experiences up to 7680 x 4320. The inclusion of 3rd gen Ray Tracing Cores and 4th gen Tensor Cores further enhances your gaming with realistic lighting and shadows.
  • Advanced gaming technologies
    This graphics card is packed with innovations including NVIDIA DLSS 3, NVIDIA G-Sync ready, NVIDIA Reflex, and Nvidia Broadcast, offering a competitive edge in gaming and streaming. The NVIDIA Ada Lovelace GPU technology ensures that gamers experience advanced graphics and performance.
MSI Geforce RTX 4070 Ti SUPER 16G GAMING X SLIM - graphics card - GeForce RTX 4070 Ti Super - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
16 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2670 MHz
CUDA Cores
8448
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5.1 cm x 30.7 cm x 12.5 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2670 MHz
CUDA Cores
8448
Max Resolution
7680 x 4320 at 60 Hz
4
Interfaces Details
API Supported
Triple Fan Design, NVIDIA G-Sync ready, Core Pipe, nickel plated copper heatpipes, MSI Zero Frozr technology, metal backplate, TriFrozr 3 Thermal Design, Airflow Control technology, Torx 5.0 Fans, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Broadcast, Nvidia Studio, Optical Flow Accelerator, screen cooling, Dual ball Bearing Fans, DrMOS, Custom PCB, Variable Refresh Rate (VRR), HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
256-bit
Required Power Supply
700 W
Additional Requirements
16 pin PCI Express power connector
285 Watt
Graphics card support bracket
Software Included
MSI Center, GeForce Game Ready Drivers, NVIDIA Studio drivers, MSI Afterburner
DisplayPort 1.4a
5.1 cm
30.7 cm
12.5 cm
1.094 kg
Shipping Weight
1.676 kg
