MSI GeForce RTX 4070 SUPER 12G GAMING X SLIM Graphics Card
Quicklinx: HVJCWS00 Mfr#: RTX 4070 SUPER 12G GAMING X SL
The MSI GeForce RTX 4070 SUPER 12G GAMING X SLIM video card is engineered for gamers and creators seeking high performance and reliability. This graphics card features a robust 12 GB of GDDR6X SDRAM and a high boost clock speed of 2640 MHz, making it capable of handling demanding games and creative projects with ease. With support for DirectX 12 Ultimate and OpenGL 4.6, users can enjoy compatibility with a variety of games and applications.
The GeForce RTX 4070 SUPER is not just about performance; it also boasts cooling technologies, including the TriFrozr 3 Thermal Design, Torx 5.0 Fans, and a nickel-plated copper base, ensuring that the card remains cool and stable even during intense gaming sessions. Additionally, its support for up to 4 monitors allows for an immersive gaming experience and enhanced productivity for creative tasks. Whether you're battling in AAA titles, creating stunning 3D models, or streaming content, the GeForce RTX 4070 SUPER 12G GAMING X SLIM is designed to deliver high performance and quality.
  • Enhanced cooling
    The GeForce RTX 4070 SUPER 12G GAMING X SLIM features the TriFrozr 3 Thermal Design, incorporating Torx 5.0 Fans and Core Pipe technology to ensure efficient cooling performance. This cooling system keeps the card operating smoothly, even under heavy loads, by efficiently dissipating heat through its nickel-plated copper base and metal backplate.
  • Immersive graphics
    Equipped with 3rd gen Ray Tracing Cores and 4th gen Tensor Cores, the NVIDIA GeForce RTX 4070 SUPER delivers stunning visuals and real-time ray tracing capabilities. Experience lifelike lighting, reflections, and shadows for an immersive gaming experience that brings virtual worlds to life.
  • High-speed performance
    With a boost clock speed of 2640 MHz and 12 GB of GDDR6X SDRAM, this graphics card is designed for gamers and creators who demand high performance. The 192-bit memory interface and 21 Gbps memory speed work together to handle demanding games and creative projects.
  • Advanced connectivity
    Supporting up to 4 monitors with HDMI and DisplayPort outputs, the GeForce RTX 4070 SUPER 12G GAMING X SLIM offers versatile connectivity options. Whether you're gaming, streaming, or multitasking, this graphics card provides the capability to create a comprehensive and immersive workstation.
MSI GeForce RTX 4070 SUPER 12G GAMING X SLIM - graphics card - GeForce RTX 4070 Super - 12 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
12 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2640 MHz
CUDA Cores
7168
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
OpenGL 4.6, DirectX 12 Ultimate
4.6 cm x 30.7 cm x 12.5 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2640 MHz
CUDA Cores
7168
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Airflow Control technology, Core Pipe, Custom PCB, DrMOS, Dual ball Bearing Fans, metal backplate, MSI Zero Frozr technology, nickel plated copper base, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA G-Sync ready, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Studio, Optical Flow Accelerator, Torx 5.0 Fans, TriFrozr 3 Thermal Design, Triple Fan Design, vented backplate, HDCP
Size
12 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
192-bit
Required Power Supply
650 W
Additional Requirements
16 pin PCI Express power connector
245 Watt
Graphics card support bracket
Software Included
MSI Center, MSI Afterburner
DisplayPort 1.4a
4.6 cm
30.7 cm
12.5 cm
972 g
Shipping Weight
1.585 kg
