MSI GeForce RTX 4060 VENTUS 2X WHITE 8G OC Graphics Card
Quicklinx: HVJ6WS00 Mfr#: RTX 4060 VENTUS 2X WHITE 8G OC
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 4060
Interface: PCI Express 4.0 x8
£251.45 ex VAT
£301.74 inc VAT
VENTUS delivers a solid experience for users seeking high performance. An updated design with TORX 4.0 fans allows VENTUS to tackle any task.
  • Torx Fan 4.0
    Torx Fan 4.0 is based on teamwork, with pairs of fan blades connected by an outer ring that concentrates airflow in the Dual-Fan cooling system.
  • Fuses
    Additional fuses built into the custom PCB provide additional safeguards against electrical damage.
  • Revolutionary Thermal Design
    Two fans on a huge heatsink ensure a cool and quiet experience.
MSI GeForce RTX 4060 VENTUS 2X WHITE 8G OC - graphics card - GeForce RTX 4060 - 8 GB - white
Graphics card
Bus Type
PCI Express 4.0 x8
Graphics Engine
8 GB GDDR6
Memory Speed
17 Gbps
Boost Clock
2490 MHz
Boost Clock (OC)
2505 MHz
CUDA Cores
3072
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI (supports 4K@120Hz as specified in HDMI 2.1a) , DisplayPort (version 1.4a)
API Supported
DirectX 12 Ultimate, OpenGL 4.6
4.1 cm x 19.9 cm x 12 cm
Enclosure Colour
White
Graphics card
Bus Type
PCI Express 4.0 x8
Graphics Engine
Boost Clock
2490 MHz
Boost Clock (OC)
2505 MHz
CUDA Cores
3072
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Dual Fan Design, 2-slot Fan Cooler, Torx 4.0 Fans, MSI Zero Frozr technology, reinforced backplate, NVIDIA Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA DLSS 3, Nvidia Broadcast, Nvidia Studio, NVIDIA Reflex, Metal Backplate with Thermal Pad, fuse protection, HDCP
Size
8 GB
GDDR6 SDRAM
Memory Speed
17 Gbps
Bus Width
128-bit
Required Power Supply
550 W
Additional Requirements
8 pin PCI Express power connector
115 Watt
Software Included
MSI Center, MSI Afterburner
4.1 cm
19.9 cm
12 cm
546 g
Shipping Weight
783 g
Enclosure Colour
White
Brand: MSI
