MSI GeForce RTX 3060 VENTUS 2X 12G OC Graphics Card
Quicklinx: HVJ8WS00 Mfr#: RTX 3060 VENTUS 2X 12G OC
VENTUS brings a performance-focused design that maintains the essentials to accomplish any task at hand. Rocking a trusted dual fan arrangement laid into a rigid industrial design lets this sharp-looking graphics card fit into any build.
  • TORX Fan 3.0
    The MSI TORX Fan 3.0 design keeps the limits of thermal performance turning. Fan blades alternate between traditional blades and dispersion blades that focus and accelerate airflow into the heatsink.
  • Zero Frozr
    Zero Frozr is the calm before the storm. The fans completely stop when temperatures are relatively low, eliminating all noise when active cooling is unneeded. The fans will automatically start spinning again when the heat is on during gaming.
  • Thermal padding
    Ample amounts of thermal pads allow various board components to transfer heat directly to the heatsink for better cooling.
  • Tailored PCB design
    Not all circuit boards are created equal. A custom PCB design provides greater reliability and beefed up power circuitry for pushing the card to its limits.
MSI GeForce RTX 3060 VENTUS 2X 12G OC - graphics card - GF RTX 3060 - 12 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 3060 - up to
12 GB GDDR6
Memory Speed
15 Gbps
Boost Clock
1807 MHz
CUDA Cores
3584
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.6
4.2 cm x 23.5 cm x 12.4 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
1807 MHz
CUDA Cores
3584
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
NVIDIA G-Sync ready, NVIDIA Adaptive Vertical Sync, MSI Zero Frozr technology, Torx 3.0 Fans, MSI Afterburner, Dual Fan Design, NVIDIA Ampere GPU technology, Nvidia RT Core, NVIDIA Tensor Core, Real-Time Ray Tracing, Nvidia DLSS, OC Scanner, HDCP
Size
12 GB
GDDR6 SDRAM
Memory Speed
15 Gbps
Bus Width
192-bit
Required Power Supply
550 W
Additional Requirements
8 pin PCI Express power connector
170 Watt
Software Included
MSI Dragon Gaming Center, MSI Afterburner
DisplayPort 1.4
4.2 cm
23.5 cm
12.4 cm
675 g
Shipping Weight
1.03 kg
