VENTUS brings a performance-focused design that maintains the essentials to accomplish any task at hand. Rocking a trusted dual fan arrangement laid into a rigid industrial design lets this sharp-looking graphics card fit into any build.
TORX Fan 3.0
The MSI TORX Fan 3.0 design keeps the limits of thermal performance turning. Fan blades alternate between traditional blades and dispersion blades that focus and accelerate airflow into the heatsink. -
Zero Frozr
Zero Frozr is the calm before the storm. The fans completely stop when temperatures are relatively low, eliminating all noise when active cooling is unneeded. The fans will automatically start spinning again when the heat is on during gaming. -
Thermal padding
Ample amounts of thermal pads allow various board components to transfer heat directly to the heatsink for better cooling. -
Tailored PCB design
Not all circuit boards are created equal. A custom PCB design provides greater reliability and beefed up power circuitry for pushing the card to its limits.
- MSI GeForce RTX 3060 VENTUS 2X 12G OC - graphics card - GF RTX 3060 - 12 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 3060 - up to
- Memory
- 12 GB GDDR6
- Memory Speed
- 15 Gbps
- Boost Clock
- 1807 MHz
- CUDA Cores
- 3584
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.6
- 4.2 cm x 23.5 cm x 12.4 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Boost Clock
- 1807 MHz
- CUDA Cores
- 3584
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- NVIDIA G-Sync ready, NVIDIA Adaptive Vertical Sync, MSI Zero Frozr technology, Torx 3.0 Fans, MSI Afterburner, Dual Fan Design, NVIDIA Ampere GPU technology, Nvidia RT Core, NVIDIA Tensor Core, Real-Time Ray Tracing, Nvidia DLSS, OC Scanner, HDCP
- Size
- 12 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 15 Gbps
- Bus Width
- 192-bit
- Required Power Supply
- 550 W
- Additional Requirements
- 8 pin PCI Express power connector
- 170 Watt
- Software Included
- MSI Dragon Gaming Center, MSI Afterburner
- DisplayPort 1.4
- 4.2 cm
- 23.5 cm
- 12.4 cm
- 675 g
- Shipping Weight
- 1.03 kg
