MSI GeForce RTX 3050 VENTUS 2X XS 8G OC Graphics Card
Quicklinx: HX32WS00 Mfr#: RTX 3050 VENTUS 2X XS 8G OC
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 3050
Interface: PCI Express 4.0 x8
44 In Stock
£180.38 ex VAT
£216.45 inc VAT
VENTUS offers a performance-centric design that keeps the essentials for performing any task at your fingertips. The reliable dual-fan layout in a rigid industrial design allows this sharp-looking graphics card to fit into any build. Not all PCBs are the same. A custom PCB design offers increased reliability and enhanced power circuits to push the board to its limits.
  • High-performance memory
    Equipped with 8 GB of GDDR6 SDRAM, the graphics card provides ample memory for demanding tasks and gaming, ensuring seamless performance.
  • Dual fan design
    The dual fan setup promotes effective cooling, allowing for extended use and performance in graphically intensive applications without overheating.
  • Power-efficient operation
    With a power consumption of only 115 W during operation, the graphics card balances performance and efficiency, ideal for energy-conscious users.
  • Multi-monitor support
    This graphics card can support up to three monitors, enabling expansive setups for multitasking or immersive gaming experiences.
  • Robust build quality
    The reinforced backplate and custom PCB design provide added stability and durability, ensuring longevity and reliable performance.
MSI GeForce RTX 3050 VENTUS 2X XS 8G OC - graphics card - GF RTX 3050 - 8 GB
Graphics card
Bus Type
PCI Express 4.0 x8
Graphics Engine
8 GB GDDR6
Memory Speed
14 Gbps
Boost Clock
1807 MHz
CUDA Cores
2560
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
3
Interfaces Details
HDMI , DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
4.5 cm x 20.5 cm x 11.2 cm
Graphics card
Bus Type
PCI Express 4.0 x8
Graphics Engine
Boost Clock
1807 MHz
CUDA Cores
2560
Max Resolution
7680 x 4320
3
Interfaces Details
API Supported
Dual Fan Design, 2-slot Fan Cooler, NVIDIA G-Sync ready, reinforced backplate, MSI Zero Frozr technology, Custom PCB, HDCP
Size
8 GB
GDDR6 SDRAM
Memory Speed
14 Gbps
Bus Width
128-bit
Required Power Supply
500 W
Additional Requirements
6 pin PCI Express power connector
115 Watt
Software Included
MSI Center, MSI Afterburner
HDCP, DisplayPort 1.4a
4.5 cm
20.5 cm
11.2 cm
570 g
Shipping Weight
744 g
Brand: MSI
