A graphics card is the single most important element for more FPS. As gamers, MSI understand that not just any graphics card "will do". That's why MSI bring you the best of the best. MSI don't want to bug you with noise and heat, but MSI do want to give you more performance. With MSI Gaming series graphics cards you get just that.
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability.
Pre overclocked
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability. -
Advanced Twin Frozr IV
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked of the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means. The other part that the Twin Frozr cooler uses is a large aluminum fin grid array that provides a huge amount of surface area for cooling. Heat from the GPU is transferred to the fin grid array by virtue of heat pipes with MSI's special SuperPipe technology. SuperPipes transfer heat twice as fast as regular heat pipes enabling an MSI Gaming graphics card to stay cooler than the competition. -
Military class component
One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components for its Gaming cards because only these components have proven to be able to withstand the torturous circumstances of extreme gaming and overclocking. -
Hi-c CAP
A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP's MSI mainboards are the most energy efficient in the market. -
Solid CAP
One With their aluminum core design, Solid CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan. -
Super Ferrite Chokes
Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability. -
Afterburner
MSI Afterburner has quickly become the favorite overclocking software for media, overclockers and end-users. Because of its simple interface, it's easy to learn, but it packs a lot of powerful features like an integrated benchmark utility called Kombustor that can check your system performance in benchmarking mode, or run as a stability test.
- MSI N760-2GD5/OC - graphics card - GF GTX 760 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 760
- Memory
- 2 GB GDDR5
- Core Clock
- 1006 MHz
- Boost Clock
- 1072 MHz
- CUDA Cores
- 1152
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 256-bit
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
- API Supported
- DirectX 11.1, OpenGL 4.3
- 3.8 cm x 24.2 cm x 11.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1006 MHz
- Boost Clock
- 1072 MHz
- CUDA Cores
- 1152
- 4
- API Supported
- MSI Solid Capacitor, Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, NVIDIA GPU Boost 2.0
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 256-bit
- 170 Watt
- Included Accessories
- 2 x 6 pin power cables
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, MSI Afterburner
- 3.8 cm
- 24.2 cm
- 11.1 cm
