Turbocharge your gaming experience with the GeForce GTX 750 Ti. It's powered by first-generation NVIDIA Maxwell architecture, delivering twice the performance of previous generation cards at half the power consumption. For serious gamers, this means you get all the horsepower you need to play the hottest titles in beautiful 1080 HD resolution, all at full settings.
All Solid Capacitors
- 10 years ultra-long lifetime (under full load).
- Lower temperature and higher efficiency.
- Aluminum core for higher stability.
Afterburner Overclocking Utility
- Monitor fan speed profile.
- In-game video recording.
- iOS/Android remote control.
- Built-in DX11.2 benchmark.
GPU Boost 2.0 Technology
- Ensures the GPU runs at its peak performance and games at their highest frame rate possible.
- Offer new levels of customization including GPU temperature target, overclocking, and unlocked voltage.
3DVision Ready
- Support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC.
Video Output Function
- Dual-link DVI-D x 1
- D-Sub x 1
- HDMI x 1 (version 1.4a)
- MSI N750Ti 2GD5/OCV1 - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1059 MHz
- Boost Clock
- 1137 MHz
- Effective Memory Clock
- 5.4 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-D (dual link) , VGA , HDMI
- API Supported
- DirectX 11.2, OpenGL 4.4
- 3.3 cm x 16.5 cm x 11.2 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1059 MHz
- Boost Clock
- 1137 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 24 Hz
- API Supported
- MSI Solid Capacitor, Nvidia 3D Vision Surround Ready, Military Class Components, MSI Afterburner, NVIDIA GPU Boost 2.0, Hi-C CAP, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Software Included
- Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Live, MSI Afterburner, MSI StarOSD, MSI Dual Core Center, Norton Internet Security 2008 (60 days trial)
- MIL-STD 810G
- 3.3 cm
- 16.5 cm
- 11.2 cm
- 290 g
