New MSI GTX 660 Ti Power Edition Graphics Card with Triple Overvoltage and Enhanced PWM Design Boosts Overclocking Potential by 18.2%
The new graphics card incorporates MSI's exclusive Triple Overvoltage technology and Enhanced PWM Design architecture to boost overclocking potential by up to 18.2%. Perfect cooling is supplied by of the new Twin Frozr IV Thermal Design and exclusive Dust Removal technology automatically removes dust from the heat sink module and maintains optimum cooling performance.
Propeller Blade technology increases airflow by 20% compared to conventional fans, effectively reducing the temperature by up to 14? and operating noise by 17.1dB. The GTX 660 Ti Power Edition also features Military Class III components, emphasizing on high quality and stability to provide gamers with a smooth and dependable working environment during overclocking or gaming.
The MSI GTX 660 Ti Power Edition incorporates proprietary features and technologies in the power supply, cooling and materials that exceed the specifications of the reference board. The superior overclockability and stability make it the ideal choice among its class.
Afterburner
The MSI GTX 660 Ti Power Edition graphics card uses the MSI Power Edition architecture: Triple Overvoltage with Afterburner support allows adjustments to the GPU, Memory and PLL voltages so the full potential of the graphics card can be released and performance overclocked by up to 18.2%. The power supply has also been improved to increase current flow by 17% compared to the reference board and maintain high stability during overclocking.
Twin Frozr IV
MSI GTX 660 Ti Power Edition graphics card features the new Twin Frozr IV cooling. With MSI's proprietary Dust Removal technology, the fans automatically run in reverse at startup to optimize cooling performance. The internationally patented Propeller Blade technology delivers 20% more airflow compared to conventional fans and also increases the cooling surface. Dual 8cm temperature-controlled fans, SuperPipe technology, and nickel-plated copper base effectively reduce the temperature by up to 14? and noise by 17.1dB!
Military Class III
MSI Military Class III components have passed rigorous MIL-STD-810G testing by an independent testing laboratory to deliver the ultimate guarantee in quality and stability. Military-grade components used on the MSI GTX 660 Ti Power Edition include Tantalum Core Hi-c CAP, 30% more powerful SFC and Solid CAP with a service life of up to 10 years. The choice of materials reflects MSI's commitment to product quality, ensuring the smoothest and most dependable user experience for overclockers and gamers alike.
Product Specification
- GPU NVIDIA GeForce GTX 660 Ti
- CUDA Core 1344 Units
- Core Base Clock 1019 MHz
- Core Boost Clock 1097 MHz
- Memory Clock 6008 MHz
- Memory Size 2048MB GDDR5
- Memory Bus 192 bits
- Output DisplayPort / HDMI / DL-DVI-I / DL-DVI-D
- TDP 190 W
- Card Dimension 265x113x38 mm
- Form Factor ATX
Technology Support
- DirectX 11
- OpenGL 4.2
- PCI Express 3.0
- CUDA Y
- SLI Y (3-way)
- PhysX Y
- 3D Vision Surround Y,3 output per card
- PureVideo HD Y
- HDCP Y
Accessory
- Driver CD Y
- Manual Y
- Installation Guide Y
- 6-pin Power Cable Y (2 pcs)
- DVI to VGA Dongle Y (1 pc)
PCI Express gen 3 standard
This advanced manufacturing technology reduces operating temperatures and improves performance, and when combined with the latest connectivity standard it can also deliver a staggering 32 GB/s of bandwidth with compatible CPUs and mainboards. For gamers, this means an even better gaming experience with 40% more performance than previous generation GeForce GTX 580 graphics cards. -
Afterburner
Afterburner co-development by MSI and Rivatuner, MSI releases the ultimate graphics card utility "Afterburner". This utility enables all MSI graphics cards users to boost performance and to monitor all kinds of critical information in real-time. Afterburner is a completely free utility which is compatible with almost all MSI graphics cards. -
HDMI + DVI output
HDMI + DVI Output HDMI and DVI are the most comprehensive used interfaces for high definition video display. MSI adopts two interfaces to provide a complete output solution for users to enjoy the latest HD video such as Blu-ray movie. -
Meet RoHS regulations
MSI products are the first to be in conformity of the EU's RoHS (Restriction of Hazardous Substances) regulations, reducing heavy metals and toxic materials in the products. This is an effort made for the Earth, and essentially for a clean future. -
NVIDIA SLI technology
Delivers up to 2x the performance of a single GPU configuration for unequaled gaming experiences by allowing two cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI technology dramatically scales performance on today's hottest games. -
HDMI convertible output
Dual-link DVI convertible output supports Video/Audio signal integration through DVI to HDMI interface, which drivers resolution of a digital display up to 1920 x 1200 or higher. -
PhysX
PhysX is designed specifically for hardware acceleration by powerful processors with hundreds of cores. Combined with the tremendous parallel processing capability of the GPU, PhysX will provide an exponential increase in physics processing power and will take gaming to a new level delivering rich, immersive physical gaming environments.
- MSI N660Ti PE 2GD5/OC - graphics card - GF GTX 660 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 660 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1019 MHz
- Boost Clock
- 1097 MHz
- CUDA Cores
- 1344
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 192-bit
- DisplayPort , HDMI , DVI-I (dual link) , DVI-D (dual link) , VGA - with adapter
- API Supported
- DirectX 11, OpenGL 4.2
- 3.8 cm x 26.5 cm x 11.3 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1019 MHz
- Boost Clock
- 1097 MHz
- CUDA Cores
- 1344
- API Supported
- Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Triple Over Voltage, Dual Fan Design, Dust Removal Technology, MSI Afterburner, Military Class III Components, Twin Frozr IV Thermal Design, Enhanced PWM Design, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 192-bit
- Additional Requirements
- CD-ROM
- 190 Watt
- Included Accessories
- 2 x 6 pin power cables
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, MSI Afterburner
- 3.8 cm
- 26.5 cm
- 11.3 cm
