Cooling the way to performance: Better cooling, better performance
MSI is happy to announce the availability of NVIDIA's latest GPU the GEFORCE GTX 660 The new MSI GTX 660 Twin Frozr 2GD5/OC introduce NVIDIA's 28nm GPUs to the crowd looking for a great price/performance ratio in their products. You can find MSI's Twin Frozr III on the MSI GTX 660 Twin Frozr 2GD5/OC where it promises to reduce GPU temperature up to 25% and noise by almost one third.
Afterburner - raise your performance
MSI Afterburner is the de-facto standard overclocking software for enthusiasts and media around the world. When equiped with enhanced Thermal Designs like the Twin Frozr III the overclocking potential is simply higher.
Propeller Blade technology
Twin Frozr coolers are equipped with MSI's patented Propeller Blade technology. The fans feature unique air channels on the fan edges to boost cooling performance by increasing the cooling area and providing 20% more airflow compared to conventional fans. This reduces temperatures and fan noise leading to a comfortable experience, no matter if you're browsing the web, watching a movie or playing the latest games.
Technical specifications
- Name N660 TF 2GD5/OC
- GPU NVIDIA GeForce GTX 660
- Codename GK106
- CUDA Cores 960
- Core/Boost Clock 1033/1098
- Memory 2GB GDDR5 @ 6008 MHz
- Output DP / HDMI / DL-DVI-I / DL-DVI-D
- TDP 150w
- MSI N660 TF 2GD5/OC - graphics card - GF GTX 660 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 660
- Memory
- 2 GB GDDR5
- Core Clock
- 1033 MHz
- Boost Clock
- 1098 MHz
- CUDA Cores
- 960
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 192-bit
- Max Monitors Supported
- 4
- Interfaces Details
- DisplayPort , HDMI , DVI-I (dual link) , DVI-D (dual link) , VGA - with adapter
- API Supported
- DirectX 11, OpenGL 4.2
- 3.58 cm x 23.5 cm x 12.52 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1033 MHz
- Boost Clock
- 1098 MHz
- CUDA Cores
- 960
- 4
- API Supported
- MSI SuperPipe Technology, MSI Solid Capacitor, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia 2-way SLI ready, Twin Frozr III Thermal Design, Propeller Blade Technology, dual 8CM PWM fans, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 192-bit
- 150 watt
- Included Accessories
- 6 pin PCIe power cable
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, MSI Afterburner
- 3.58 cm
- 23.5 cm
- 12.52 cm
