Game in style and dare to be different with MSI's unique ARMOR graphics cards. Inspired by advanced armor shielding with a classy finish, ARMOR graphics cards are perfect for gamers and case modders, who are looking for something different. This is where gaming meets class.
Dual fan
Armor 2X thermal design is equipped with two of the MSI TORX fans. Thanks to the blade design, MSI TORX fans provide strong cooling performance, while remaining incredibly silent. -
ZeroFrozr - stay undetected
ZeroFrozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans. -
Heatsink and airflow control
Under the classy shroud and powerful dual fans is a huge heatsink with countless aluminum fins, that help dissipate the heat from the GPU. The copper heatpipes are infused in the baseplate to ensure efficient cooling. The aluminum fins are rigged with airflow control technology to maximize airflow towards the heatpipes. -
Prepare for VR with MSI
To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. Integrating the advanced technologies in recommended MSI VR gaming hardware for smooth performance. Together with VR partners, MSI brings gamers an extremely realistic VR experience, where games come alive.
- MSI GTX 1080 Ti ARMOR 11G OC - graphics card - GF GTX 1080 Ti - 11 GB - black, white
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080 Ti - up to
- Memory
- 11 GB GDDR5X
- Core Clock
- 1531 MHz
- Boost Clock
- 1645 MHz
- CUDA Cores
- 3584
- Effective Memory Clock
- 11.016 GHz
- Memory Interface
- 352-bit
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort , 2 x HDMI , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 29 cm x 14.3 cm
- Enclosure Colour
- Black, white
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1531 MHz
- Boost Clock
- 1645 MHz
- CUDA Cores
- 3584
- VR Ready
- 4
- API Supported
- Nvidia 2-way SLI ready, MSI Afterburner, NVIDIA Adaptive Vertical Sync, NVIDIA G-Sync ready, Armor 2X Thermal Design, MSI Zero Frozr technology, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 11 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 11.016 GHz
- Bus Width
- 352-bit
- Required Power Supply
- 600 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- 250 Watt
- Software Included
- MSI Afterburner
- HDCP 2.2
- 4 cm
- 29 cm
- 14.3 cm
- 903 g
- Enclosure Colour
- Black, white
