MSI GeForce GTX 1070 ARMOR 8GB GDDR5 OC
Quicklinx: C6Q5WS00 Mfr#: GTX1070-ARMOR-8G-OC
GeForce® GTX 1070 ARMOR 8G OC
Core/Memory:
Boost Clock / Base Clock - 1746 MHz / 1556 MHz
8192 MB GDDR5 / 8008 MHz Memory
Video Output Function:
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Features:
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
THE LATEST GAMING TECHNOLOGIES
Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary new 360-degree image capture.
PERFORMANCE
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX™ 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
  • Amazing design
    Game in style & dare to be different with MSI's ARMOR graphics cards. ARMOR graphics cards are perfect for gamers and case modders who are looking for something different. This is where gaming meets class.
  • The great graphics for virtual reality
    NVIDIA's set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing.
  • Stutter, tear-free gameplay
    Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming.
  • Dual Fan design
    ARMOR 2X thermal design is equipped with two of the MSI fans. Thanks to the blade design, MSI fans provide strong cooling performance while remaining incredibly silent.
  • MSI Zero Frozr technology
    It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
  • Heatsink & airflow control
    Under the classy shroud and powerful dual fans is a huge heatsink with countless aluminum fins that help dissipate the heat from the GPU. The copper heatpipes are infused in the baseplate to ensure efficient cooling. The aluminum fins are rigged with Airflow Control technology to maximize airflow towards the heatpipes.
  • Prepare for VR with MSI
    To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. MSI brings gamers an extremely realistic VR experience where games come alive.
  • MSI Afterburner
    MSI Afterburner is the widely used graphics card overclocking utility which gives you full control of your graphics cards. It also provides an incredibly detailed overview of your hardware and comes with some additional features such as customizing fan profiles, benchmarking and video recording.
MSI GTX 1070 ARMOR 8G OC - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070
8 GB GDDR5
Core Clock
1556 MHz
Boost Clock
1746 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 27.9 cm x 14 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1556 MHz
Boost Clock
1746 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia 2-way SLI ready, Dual Fan Design, Airflow Control technology, NVIDIA G-Sync ready, MSI Zero Frozr technology, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
256-bit
Required Power Supply
500 W
150 Watt
Software Included
MSI Afterburner
3.7 cm
27.9 cm
14 cm
832 g
Limited warranty - parts and labour - 3 years
