GEFORCE GTX 1060
10: Gaming Perfected
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal™—the most advanced GPU architecture ever created—the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. #GameReady.
NVIDIA PASCAL
THE WORLD'S MOST ADVANCED GPU ARCHITECTURE
GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences.
Dual fan
ARMOR 2X thermal design is equipped with two of the Torx fans. Thanks to the blade design, MSI Torx fans provide strong cooling performance while remaining incredibly silent. -
Heatsink and Airflow Control
Under the classy shroud and powerful dual fans is a huge heatsink with countless aluminum fins, that help dissipate the heat from the GPU. The copper heatpipes are infused in the baseplate to ensure efficient cooling. The aluminum fins are rigged with Airflow Control technology to maximize airflow towards the heatpipes. -
Prepare for VR with MSI
To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. Integrating the optimal of advanced technologies in recommended MSI VR gaming hardware for smooth performance. Together with the VR partners, MSI brings gamers an extremely realistic VR experience, where games come alive.
- MSI GTX 1060 ARMOR 6G OC - graphics card - GF GTX 1060 - 6 GB - black, white
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 6 GB GDDR5
- Core Clock
- 1544 MHz
- Boost Clock
- 1759 MHz
- Effective Memory Clock
- 8 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.8 cm x 27.9 cm x 14 cm
- Enclosure Colour
- Black, white
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1544 MHz
- Boost Clock
- 1759 MHz
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Nvidia 2-way SLI ready, MSI Afterburner, 6 Phase PWM Design, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, NVIDIA G-Sync ready, NVIDIA GameWorks, Torx Fans, Armor 2X Thermal Design, MSI Zero Frozr technology, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- 120 Watt
- 3.8 cm
- 27.9 cm
- 14 cm
- 737 g
- Enclosure Colour
- Black, white
