With every generation of GPUs comes more performance. Twin Frozr V is smaller, features stronger fans, generates less noise, keeps your graphics card and its components cooler and matches perfectly with your MSI Gaming motherboard including some funky LED lightning.
MSI has fitted Twin Frozr coolers with the Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency.
Twin Frozr V - cooler, quieter, better gaming
With every generation of GPUs comes more performance. Twin Frozr V is smaller, features stronger fans, generates less noise, keeps your graphics card and its components cooler and matches perfectly with your MSI Gaming motherboard including some funky LED lightning. -
Enhanced dissipation efficiency
MSI has fitted Twin Frozr coolers with the Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency. -
SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI Gaming series graphics card. Additionally, the heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design. -
Smart cooling, stay quiet
MSI's Twin Frozr V Thermal designs are equipped with Zero Frozr technology which was first introduced by MSI back in 2008. Zero Frozr technology eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there's a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC. -
Catching the Vibe with Cool LED effects
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click. -
More performance
MSI Gaming Graphics Cards give you more performance out of the box. Whether you use the card pre-overclocked or use the Gaming App to use its full potential, you can just get right into the game and enjoy sublime performance. Overclocking through the MSI Gaming App is covered by warranty to take away your worries. Get in there and start winning! -
Afterburner
MSI Afterburner is world's favorite cross-vendor GPU overclocking tool. The easy interface gives access to the most detailed information about your graphics card and allows for tinkering with pretty much anything available on your graphics card. -
Predator
A built-in screen and video capturing tool named Predator which captures your screen as still images or videos with the push of a button and allows you to capture and record your coolest, goofiest and most awesome gaming moments on your PC!
- MSI GTX 960 Gaming 4G - graphics card - GF GTX 960 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 960
- Memory
- 4 GB GDDR5
- Core Clock
- 1241 MHz
- Boost Clock
- 1304 MHz
- Effective Memory Clock
- 7.01 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / HDMI: 4096 x 2160 at 24 Hz; 3840 x 2160 at 60 Hz
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 3 x DisplayPort , HDMI , VGA - with adapter
- API Supported
- OpenGL 4.4, DirectX 12
- 4 cm x 26.7 cm x 13.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1241 MHz
- Boost Clock
- 1304 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- MSI SuperPipe Technology, MSI Solid Capacitor, Nvidia 3D Vision technology, Nvidia 2-way SLI ready, Nvidia Surround technology, MSI Afterburner, NVIDIA GPU Boost 2.0, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, Twin Frozr V Thermal Design, Torx Fans, SuperSU Architecture, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- 120 watt
- Included Accessories
- 8 pin power cable
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- MSI Afterburner, MSI Predator
- MIL-STD 810G
- 4 cm
- 26.7 cm
- 13.9 cm
- 833 g
