Enhanced visuals
Equipped with a NVIDIA GeForce GT 730 graphics processor and supporting DirectX 12 and OpenGL 4.4, this graphics card delivers rich, detailed visuals for a more immersive gaming and multimedia experience. -
High-definition support
With the capability to support up to 3 monitors and resolutions up to 4096 x 2160, users can enjoy high-definition content across multiple screens for gaming, movies, or multitasking. -
Seamless integration
The MSI N730K-1GD5LP/OC features a low-profile design and includes HDMI, DVI-D (dual link), and VGA ports, ensuring compatibility with a wide range of systems and monitors. -
Energy efficient
With a power consumption of just 49 W, this graphics card balances performance with efficiency, making it an ideal choice for users looking to enhance their PC's capabilities without significantly increasing power costs. -
Advanced audio and video
Supports DTS-HD Master Audio and Dolby True HD, along with MSI Solid Capacitor design for improved durability and reliability, offering an exceptional audiovisual experience.
- MSI N730K-1GD5LP/OC - graphics card - GF GT 730 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 730 - up to
- Memory
- 1 GB GDDR5
- Core Clock
- 1006 MHz
- Effective Memory Clock
- 5 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 1600 / HDMI: 4096 x 1600
- Max Monitors Supported
- 3
- Interfaces Details
- HDMI , DVI-D (dual link) , VGA
- API Supported
- OpenGL 4.4, DirectX 12
- 2.9 cm x 14.1 cm x 6.9 cm
- Bus Type
- Graphics Engine
- Core Clock
- 1006 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 3
- API Supported
- MSI Solid Capacitor, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Dolby True HD support, DTS-HD Master Audio support, NVIDIA Adaptive Vertical Sync, HDCP
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- 49 Watt
- Software Included
- Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Live, MSI Afterburner, MSI Dual Core Center, Norton Internet Security 2008 (60 days trial)
- 2.9 cm
- 14.1 cm
- 6.9 cm
- 202 g
