MSI GeForce GT 730 1GB PCI-E 2.0 x16 OC  DVI, D-Sub, HDMI
Quicklinx: B5Q2WS00 Mfr#: N730K-1GD5LP/OC
Marketing description is not available.
  • Enhanced visuals
    Equipped with a NVIDIA GeForce GT 730 graphics processor and supporting DirectX 12 and OpenGL 4.4, this graphics card delivers rich, detailed visuals for a more immersive gaming and multimedia experience.
  • High-definition support
    With the capability to support up to 3 monitors and resolutions up to 4096 x 2160, users can enjoy high-definition content across multiple screens for gaming, movies, or multitasking.
  • Seamless integration
    The MSI N730K-1GD5LP/OC features a low-profile design and includes HDMI, DVI-D (dual link), and VGA ports, ensuring compatibility with a wide range of systems and monitors.
  • Energy efficient
    With a power consumption of just 49 W, this graphics card balances performance with efficiency, making it an ideal choice for users looking to enhance their PC's capabilities without significantly increasing power costs.
  • Advanced audio and video
    Supports DTS-HD Master Audio and Dolby True HD, along with MSI Solid Capacitor design for improved durability and reliability, offering an exceptional audiovisual experience.
MSI N730K-1GD5LP/OC - graphics card - GF GT 730 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 730 - up to
1 GB GDDR5
Core Clock
1006 MHz
Effective Memory Clock
5 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 1600 / HDMI: 4096 x 1600
Max Monitors Supported
3
Interfaces Details
HDMI , DVI-D (dual link) , VGA
API Supported
OpenGL 4.4, DirectX 12
2.9 cm x 14.1 cm x 6.9 cm
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
1006 MHz
RAMDAC
400 MHz
Max Resolution
4096 x 2160 at 60 Hz
3
Interfaces Details
API Supported
MSI Solid Capacitor, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Dolby True HD support, DTS-HD Master Audio support, NVIDIA Adaptive Vertical Sync, HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
64-bit
Required Power Supply
300 W
49 Watt
Software Included
Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Live, MSI Afterburner, MSI Dual Core Center, Norton Internet Security 2008 (60 days trial)
2.9 cm
14.1 cm
6.9 cm
202 g
