MSI GeForce GT 710 2GB DDR3 Dual-DVI-D HDMI Graphics Card
Quicklinx: BWGBWS00 Mfr#: GT 710 2GD3H LP
Core/Memory
• 954 MHz Core
• 2048MB DDR3 1600 MHz
Video Output Function
• Dual-link DVI-D x 1
• HDMI x 1 (Version 1.4a)
• D-Sub x 1
All Solid Capacitors
10 years ultra-long lifetime (under full load).
Lower temperature and higher efficiency.
Extreme low ESR.
Noise Free
Large heat sink covers the area of GPU and memory.
Providing the best environment for gaming and multimedia.
Low Profile Design
Low profile design saves more spaces.
User can build slim or smaller system easier.
Afterburner Overclocking Utility
Support in-game video recording.
Support wireless control by android/iOS handheld devices.
Support built-in DX12 effect test.
  • Efficient cooling
    The fanless heatsink design ensures silent operation, making it perfect for use in quiet environments or media centers where noise levels are a concern.
  • Versatile connectivity
    With support for DVI-D (dual link), HDMI, and VGA interfaces, this graphics card offers flexible options for connecting to a wide range of displays, from traditional monitors to modern high-definition TVs.
  • Enhanced video performance
    Equipped with NVIDIA GeForce GT 710 and supporting DirectX 12 and OpenGL 4.5, this card delivers improved graphics performance, ensuring smoother video playback and enhanced gaming experiences.
  • Low power consumption
    With an operational power consumption of just 19 W, this graphics card is an energy-efficient choice for upgrading your system without significantly increasing your power bill.
  • Compact and compatible
    The low-profile design of this graphics card makes it compatible with a wide range of systems, including small form factor PCs, ensuring easy installation and a perfect fit.
MSI GT 710 2GD3H LP - graphics card - GF GT 710 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
2 GB DDR3
Core Clock
954 MHz
Effective Memory Clock
1.6 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
2
Interfaces Details
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 12, OpenGL 4.5
1.9 cm x 14.6 cm x 6.9 cm
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
954 MHz
RAMDAC
400 MHz
Max Resolution
4096 x 2160 at 24 Hz
2
Interfaces Details
API Supported
MSI Solid Capacitor, fanless heatsink, MSI Afterburner, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.6 GHz
Bus Width
64-bit
Required Power Supply
300 W
19 Watt
Software Included
Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Afterburner, display drivers, Norton Internet Security (60 days trial)
1.9 cm
14.6 cm
6.9 cm
178 g
