Every PC deserves great graphics. The NVIDIA GeForce GT 630 graphics card is designed to deliver a premium multimedia experience and reliable entry-level PC gaming - every time. Insist on NVIDIA dedicated graphics for faster, more immersive performance in your favorite applications.
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers stunning picture clarity, smooth video, accurate color, and precise image scaling for movies and video. -
TrueHD and DTS-HD audio bitstreaming
Full support for TrueHD and DTS-HD advanced lossless multi-channel HD audio codecs brings the rich sound of the master recording to your living room. -
Microsoft DirectX 11 support
DirectX 11 GPU supports designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation. -
NVIDIA CUDA technology
NVIDIA CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding system tasks - such as photo editing - delivering incredible performance improvements over traditional CPUs. -
NVIDIA PhysX technology
Full supports for PhysX technology, enabling a class of physical gaming interaction for a more dynamic and realistic experience with GeForce. -
NVIDIA adaptive vertical sync
Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. -
HDMI
Support for HDMI including GPU accelerated Blu-ray 3D support, x.v.Color, HDMI deep color, and digital surround sound. -
Dual-link DVI
Able to drive industries large and high resolution flat-panel displays up to 2560 x 1600. -
PCI Express 2.0 support
Designed for the PCI Express 2.0 bus architecture offering the high data transfer speeds for the most bandwidth-hungry games, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
- MSI N630GT-MD2GD3 - graphics card - GF GT 630 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 630
- Memory
- 2 GB
- Core Clock
- 810 MHz
- CUDA Cores
- 96
- Effective Memory Clock
- 1 GHz
- Memory Interface
- 128-bit
- DVI-I (dual link) , HDMI , VGA
- API Supported
- DirectX 11, OpenGL 4.2
- 3.3 cm x 17.8 cm x 7.3 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- CUDA Cores
- 96
- API Supported
- Native HDMI, MSI Solid Capacitor, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Dolby True HD support, DTS-HD Master Audio support, HDCP
- Size
- 2 GB
- Effective Clock Speed
- 1 GHz
- Bus Width
- 128-bit
- 56 Watt
- Software Included
- Drivers & Utilities, MSI Afterburner
- 3.3 cm
- 17.8 cm
- 7.3 cm
