MSI GeForce GT 630 810MHz 2GB PCI-Express HDMI
Quicklinx: 84Y7WS00 Mfr#: N630GT-MD2GD3
  • High-Definition Multimedia Interface (HDMI)
Every PC deserves great graphics. The NVIDIA GeForce GT 630 graphics card is designed to deliver a premium multimedia experience and reliable entry-level PC gaming - every time. Insist on NVIDIA dedicated graphics for faster, more immersive performance in your favorite applications.
  • NVIDIA PureVideo HD technology
    The combination of high-definition video decode acceleration and post-processing that delivers stunning picture clarity, smooth video, accurate color, and precise image scaling for movies and video.
  • TrueHD and DTS-HD audio bitstreaming
    Full support for TrueHD and DTS-HD advanced lossless multi-channel HD audio codecs brings the rich sound of the master recording to your living room.
  • Microsoft DirectX 11 support
    DirectX 11 GPU supports designed for ultra high performance in the API's key graphics feature, GPU-accelerated tessellation.
  • NVIDIA CUDA technology
    NVIDIA CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding system tasks - such as photo editing - delivering incredible performance improvements over traditional CPUs.
  • NVIDIA PhysX technology
    Full supports for PhysX technology, enabling a class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
  • NVIDIA adaptive vertical sync
    Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
  • HDMI
    Support for HDMI including GPU accelerated Blu-ray 3D support, x.v.Color, HDMI deep color, and digital surround sound.
  • Dual-link DVI
    Able to drive industries large and high resolution flat-panel displays up to 2560 x 1600.
  • PCI Express 2.0 support
    Designed for the PCI Express 2.0 bus architecture offering the high data transfer speeds for the most bandwidth-hungry games, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
MSI N630GT-MD2GD3 - graphics card - GF GT 630 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
2 GB
Core Clock
810 MHz
CUDA Cores
96
Effective Memory Clock
1 GHz
Memory Interface
128-bit
DVI-I (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.2
3.3 cm x 17.8 cm x 7.3 cm
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
810 MHz
CUDA Cores
96
API Supported
Native HDMI, MSI Solid Capacitor, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Dolby True HD support, DTS-HD Master Audio support, HDCP
Size
2 GB
Effective Clock Speed
1 GHz
Bus Width
128-bit
56 Watt
Software Included
Drivers & Utilities, MSI Afterburner
3.3 cm
17.8 cm
7.3 cm
