Experience better image quality, the wide viewing angle panel enhanced more contrast level and more brightness level with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side. Each color on this notebook is delivered with high precision in detail, guaranteeing excellent color fidelity for many use. Nahimic sound technology offers immersive virtual 7.1 sound in high definition using advanced stereo equipment.
SHIFT technology
The MSI SHIFT technology minimizes noise and temperature. Switch between three profiles to reach balance between system performance and comfortable user experience. -
Cooler Boost 3
MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A total of 4 heat pipes and dual fans actively and effectively push heat out of the system. -
DDR4-2133 memory support
Get high performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high reading and writing speeds. -
True Color technology
MSI True Color technology guarantees that each panel in a MSI notebook comes with fine precision in color. Each color is delivered with high precision in detail, guaranteeing excellent color fidelity for many use applications. -
Matrix Display
MSI Matrix Display supports up to 3 external displays simultaneously. Multitask is made possible even during competitive gameplays. Connect the laptop to HDTV display, Matrix Display supports 4K output. MSI Matrix Display technology creates an optimal environment for extreme gaming experience and pleasant multimedia entertainment. -
Wide viewing angle display
Experience better image quality, the wide viewing angle panel enhanced more contrast level and more brightness level with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side. -
Nahimic sound technology offers immersive virtual 7.1 sound in high definition using advanced stereo equipment. -
Sound by Dynaudio
This audio feature creates a realistic sound and immersive effects. Any high-quality stereo source is transformed into true-to-life, multichannel sound. -
Audio Boost 2
Audio Boost 2 provides gamers a more detailed aural picture of their surroundings, helping in-game, while also minimizing distortion and providing a powerful amplifier which has no trouble powering even demanding gaming headsets. Gold-plated jacks will give you less noise interference and ensure the long-term durability of the jack. -
A keyboard all gamers desire for
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions. -
Killer Gaming LAN
In the gaming battlefield, speed defines the winner. Stop losing games to lag with Killer Gaming LAN. The advanced stream detect protects networking traffic and prevents lag spikes through controlling and managing.
- MSI GE72 6QF 014UK Apache Pro - 17.3" - Intel Core i7 6700HQ - 16 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 970M
- Video Memory
- 3 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell
- Black
- 41.99 cm x 28.78 cm x 3.2 cm
- 2.9 kg
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD M.2
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 72% NTSC
- Anti-glare, WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Camera
- Yes - 720p
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost 2, Nahimic sound technology
Input
- Keyboard, touchpad
- SteelSeries Full Color
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3160
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Killer Ethernet E2400
- Killer Shield
- Technology
- 6-cell
- Capacity
- 60 Wh
AC Adapter
- Output
- 150 Watt
Connections & Expansion
- LAN , Microphone input , Headphone output , 2 x USB 3.0 , HDMI , Mini DisplayPort , USB 2.0 , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- MSI BurnRecovery, Norton Online Backup (30 days trial), Norton Internet Security (60 days trial), MSI Remind Manager, MSI Battery Calibration, Skype (Metro UI), Fresh Paint (Metro UI), EverNote (Metro UI), Microsoft Office 2013 (30 days trial), MSI Boot Configure, MSI Social Media Collection, MSI Dragon Gaming Center, Bewise CookBook (Metro UI), Green Field Puzzle (Metro UI), Hit Hot TuMetro (Metro UI), Corel Winzip, MSI System Control Manager, WildTangent Game (Metro UI), Norton Studio (Metro UI), Microsoft Essential 2012, Microsoft Wordament (Metro UI), Microsoft Game Pack (Metro UI), Creative Sound Blaster Cinema 2, Line (Metro UI)
- Black
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 2.9 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
