MSI DC100 White AMD E450 2gb 320GB No OS
Quicklinx: 7PKVWS00 Mfr#: DC100-010XEU
  • IEEE 802.11n
The Wind Box DC100 provides outstanding energy-saving capabilities and combines with three main concepts - small, simple and smart to define its product values. The Wind Box DC100 is equipped with the AMD Brazos platform E-450 dual-core processor, ensuring first-class computing performance.
  • Eco-chic design
  • Plus dual-core high performance
    The Wind Box DC100 supports both of the mainstream output interfaces: VGA and HDMI. It features the AMD Radeon HD discrete class graphics, with output resolution of up to 1080p, and supports DirectX 11 image processing technology, enabling users to enjoy high-definition digital content whatever they want.
  • Simple - streamlined APU, performance and vision altogether
    The Wind Box DC100 uses the AMD Brazos platform, with built-in AMD E-450 APU (Accelerated Processing Unit). It supports a dual-core processor and Radeon HD discrete class graphics performance; the energy consumption of the processor is just 18 W.
  • Smart - an ultra-lightweight PC
    The Wind Box DC100 has smooth lines and a slim, lightweight chassis. The DC100's unique "snowboard" style base makes it easy to store and move around; this ultra-mini PC is perfect for both home and office use. Tests have confirmed that, in regular operation, the Wind Top DC100 maintains average power consumption that does not exceed 40 W, less than half that of most conventional PCs.
MSI WindBOX DC100-010XEU - USFF - E-450 1.65 GHz - AMD VISION - 2 GB - HDD 320 GB
Personal computer - ultra small form factor
Platform Technology
AMD VISION
AMD E-450 1.65 GHz (Dual-Core)
RAM
2 GB (installed) / 4 GB (max) - DDR3 SDRAM
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 320 GB - SATA 3Gb/s - 5400 rpm
Optical Storage
No optical drive
Card Reader
6 in 1
Graphics Controller
AMD Radeon HD 6320 Shared Video Memory (UMA)
Audio Output
5.1 channel surround - integrated
10Mb LAN, 100Mb LAN, 802.11b/g/n
OS Provided
No operating system
Image Colour Disclaimer
The displayed product image may be a different colour
3.5 cm x 19.2 cm x 15.1 cm
0.83 kg
Platform Technology
AMD VISION
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
AMD E-450
Clock Speed
1.65 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
Chipset Type
AMD A50M
RAM
Installed Size
2 GB / 4 GB (max)
DDR3 SDRAM
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 2 GB
Hard Drive
HDD
1 x 320 GB
Interface Type
SATA 3Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 3Gb/s
Optical Storage
No optical drive
Card Reader
6 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, HDMI
Audio Output
Integrated
Sound Output Mode
Integrated
Wireless LAN Supported
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Bays
Internal 3.5"
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin
6 x USB 2.0 (4 front, 2 rear) , 1 x HDMI output , 1 x VGA output , 1 x TOSLINK , 1 x LAN , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-out (1 rear)
RoHS, EuP Ready
Power adapter
Power Provided
40 Watt
80 PLUS Certification
80 PLUS
Operating System / Software
OS Provided
No operating system
3.5 cm
19.2 cm
15.1 cm
0.83 kg
