MSI Creator Z17 HX Studio RTX4070 Core i9 64GB 2TB
Quicklinx: HV9XWS00 Mfr#: 9S7-17N212-243
£2,511.54 ex VAT
£3,013.84 inc VAT
The Creator Z17 HX Studio A14V, equipped with the latest generation of Intel CPU, GPU, MSI's AI-Engine, and MSI's AI-Artist functions, provides an immersive creativity experience tailored for diverse professional creators. Empowered by AI, these laptops enhance your creativity, manifesting your ideas into reality. In this new era, aesthetics are defined by you.
Premium Crafted CNC Precision
The Creator Z17 HX Studio A14V Studio features a sleek and sturdy body in a gorgeous Lunar Gray, crafted from a high-quality CNC uni-body chassis. It perfectly blends modern aesthetics with top-notch performance.
Perfect In Execution
Up to Intel CoreTM i9 processor 14900HX Unleash supremacy with the formidable Intel CoreTM i9 processor 14900HX, meticulously crafted for the creator experience. Powered by this potent CPU, the Creator Z17 HX Studio A14V can handle any task from daily creative needs or even professional level projects. Elevate your creative journey to unprecedented heights.
Your Ideas, Accelerated By NVIDIA Studio
Creativity that's all in. NVIDIA Studio is your creative advantage with state-of-the-art RTX GPUs that power top creative apps. Ray tracing delivers hyper-realistic graphics, and the Studio suite of AI-assisted tools take ideas from concept to completion, faster. Studio Drivers provide maximum reliability so you can focus on your next big idea.
Now Even Smarter
MSI Laptops now accelerate work and play even faster and more efficiently than ever before. They come standard with exclusive MSI Intelligent Technology that is capable of providing whole new Intelligent features, taking automatic tuning to a whole new level.
MSI AI Engine
MSI AI Engine is able to detect user scenarios and automatically adjust hardware settings to achieve the best performance. With simple AI tuned modes and resources, you can focus on the important things like creating, work and entertainment. Thanks to AI Noise Cancellation Pro, you still can enjoy crystal clear sound even in a noisy environment.
MSI AI Artist
Generate images directly on your laptop with MSI AI Artist. You can create rich images with shorter prompts and generate words within images. MSI AI Artist offers stunning image composition that results in realistic and amazing visuals. Create and inspire at a whole new level.
Explore Every Detail
Visualize in a new way with True Pixel display. Delivering vibrant images at QHD+ resolution, 100% DCI-P3 (Typical) color gamut, factory-calibrated Delta-E < 2 out of the box accuracy, and True Color Technology. Each panel is Calman verified for out of the box color accuracy. Indulge in the full spectrum of colors.
Unlimited Creativity
The Creator Z17 HX Studio A14V is compatible with the MSI Pen 2, supporting MSI's exclusive Precision Pen Touch technology, enabling a more versatile writing and drawing experience. Its 16:10 golden ratio display and thin bezel, a 95% display ratio, offers maximum visual real estate and fluidity. Let your imagination soar with the touchscreen display.
Vapor Chamber Cooler
With the exclusive Cooler Boost Technology, the brand-new Vapor Chamber Cooler design is a vital part of Creator Z17 HX Studio A14V. The larger heat capacity reduces the noise and temperature, keeping performance stable while using high-demanding software.
Breaking The Boundaries
The Creator Z17 HX Studio A14V provides a 90Whr long-lasting battery and fast-charge technology that adapts to your needs better than ever. Crafted with an ultra-slim 19mm metal chassis, the Creator Z17 HX Studio A14V enhances your productivity, anytime and anywhere.
Connect To All Possibilities
Creator Z17 HX Studio A14V offers a full set of high-performance I/O ports. ThunderboltTM 4 offers connectivity with state-of-the-art speed and versatility, supporting up to 40Gbps bandwidth with daisy chain capabilities. With SD Express high speed card reader, save more time when transferring your high-quality videos. Creator Z17 HX Studio A14V provides that extra flexibility to save and share your incredible ideas while staying mobile.
MSI Center
For your multi-tasking, the MSI Center takes optimization to the next level with easily adjustable system modes and resources for a wide range of scenarios and needs.
Military-Grade Durability
To pursue the best of the best, the product meets the MIL-STD-810H military standard for reliability and durability. MSI always strives for professionalism with world-leading technology.
MSI - 17" - Intel Core i9 - 2 TB SSD
Notebook
Operating System
Win 11 Pro
Intel Core i9
DDR5
Storage
2 TB SSD - NVMe
Display
17" touchscreen 2560 x 1600 / QHD+
Video Memory
GDDR6 SDRAM
Integrated Webcam
Bluetooth 5.3
Security
Fingerprint reader
Lunar grey
38.2 cm x 26 cm
2.49 kg
Notebook
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core i9
Number of Cores
24-core
Max RAM Supported
64 GB
DDR5 SDRAM
SO-DIMM 262-pin
Slots Qty
2
Storage
Main Storage
2 TB SSD - NVM Express (NVMe)
Display
17"
Touchscreen
Resolution
2560 x 1600 (QHD+)
Widescreen
Image Aspect Ratio
16:10
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Video Memory
GDDR6 SDRAM
Camera
Yes - 1080p
Frame Rate
30 frames per second
Sound
Four speakers
Input
Keyboard, touchpad
Per-key RGB
Communications
Wireless
Bluetooth 5.3
90 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Connections & Expansion
Memory Card Reader
Lunar grey
Security
Fingerprint reader
Power adapter
38.2 cm x 26 cm
2.49 kg
Sustainability Information
TCO Certified
Brand: MSI
Price Range Ex VAT: £1500+
