MSI B75MA-E33 S1155 Intel B75 DDR3 uATX
Quicklinx: 8W39WS00 Mfr#: B75MA-E33
With ultra-high transfer bandwidth, PCI Express Gen 3 provides a 2x faster transfer rate than the previous generation, this delivers amazing capabilities for true next generation extreme gaming.
O.C. Genie II provides an instant performance boost, optimizing CPU, memory, integrated graphics, and storage device performance with the function enabled.
  • Intel small business advantage
    Intel small business advantage delivers the enhanced security and productivity for PCs that small businesses demand.
  • PCI Express Gen 3 mainboard
  • O.C. Genie II
  • SATA 6 Gb/s
    SATA 6 Gb/s provides double the bandwidth of traditional SATA 3 Gb/s, and increases the data transfer rate between your mainboard and internal storage devices, such as 7200rpm HDDs, 10000 rpm HDDs and SSDs.
  • M-Flash
    Compared to common mainboard which need extra BIOS chips, MSI's M-Flash has a double advantage which doesn't need extra components and secondly, all your BIOS data will be saved in the USB drive. The stored data does not only have backup and upgrade function, moreover it can also be seen as a portable BIOS chip which is actually able to boot up your PC.
MSI B75MA-E33 - motherboard - micro ATX no CPU - LGA1155 Socket - B75
Motherboard - micro ATX
No CPU
Chipset Type
Intel B75 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series, Xeon E3-1200 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3
Storage Ports
1 x SATA-600, 3 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (1 x USB 3.0 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
No CPU
Chipset Type
Intel B75 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 3 x 7pin SATA - 3 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x HDMI , 1 x audio line-in , 1 x audio line-out , 1 x microphone
Internal Interfaces
2 x USB 2.0 - header , 1 x USB 3.0 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI support, M-Flash, UEFI BIOS, MSI ClickBIOS II
Hardware Features
Chassis intrusion detection, audio jack detect technology, OC Genie II, MSI Winki 3, MSI Solid Capacitors on PWM, Instant OC
Software Included
Drivers & Utilities, MSI Live Update 5
Plug and Play
24.4 cm
17.3 cm
