MSI B350 TOMAHAWK ARCTIC AMD B350 AM4 DDR4 M.2 USB3.1 ATX
Quicklinx: CWN0WS00 Mfr#: B350 TOMAHAWK ARCTIC
Featuring heavy-plated heat sinks and fierce looks, MSI gaming motherboards are packed with gaming features for a refined gaming experience.
  • Personalize your gaming rig
    Customize and set up your own color scheme with RGB Mystic Light sync. Select any of the colors from the palette, using your smartphone, to match your system style. Bored of the same colors? Simply change the complete look of your system fast!
  • Stay cool while gaming
    Cooling your PC is essential for reliable performance. MSI has made sure to add enough fan headers with full control to allow you to cool your system any way you want.
  • Your in-game advantage
    Outsmart and outperform your opponents in-game, using an array of unique MSI gaming tools. Clever hardware tools, created to keep you one step ahead of the competition and boost your skills.
  • Be the first on the battlefield
    This MSI gaming motherboard supports all the advanced storage standards. This allows you to connect any ultrafast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies.
  • Immerse yourself into virtual worlds
    Integrating the advanced technologies on MSI hardware provides a smooth VR ride. Through joint efforts with major VR brands, combined with unique MSI features, geared to VR, MSI brings gamers and VR professionals a vivid and realistic experience, in which content truly comes alive.
  • Sound, that pulls you into the game
    Get the immersive sound experience when gaming. MSI Audio Boost delivers the high sound quality through the use of premium-quality audio components. This lets you enjoy breathtaking, game-changing sound to create the exciting gameplay.
  • Dominate the game with the low latency
    Get ready to crush your enemies on the battlefield with MSI gaming LAN. Featuring the high-quality components, tuned to deliver the online gaming experience without lag.
  • Unmatched memory performance
    MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability.
  • Designed for limitless tuning
    Founded on experience and with a long history of creating the high-performing motherboards, packed with smart features, you can count on this motherboard to deliver the optimal performance under the extreme conditions. Countless system tuning and troubleshooting tools are at your disposal to push your system to another heights and satisfy even the demanding tweaker.
  • Maximize your USB device performance
    Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of solutions to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds.
  • Built on everlasting quality
    Using only the fine-quality components and integrating the technological innovations deliver the excellent gaming and professional experience. Rigorous quality under the extreme conditions ensures a super-reliable, high-performance motherboard.
MSI B350 TOMAHAWK ARCTIC - motherboard - ATX - Socket AM4 - AMD B350 FCH
Motherboard - ATX
Chipset Type
AMD B350 FCH
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4
Storage Ports
4 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C Gen 1 + 3 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD B350 FCH
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
Dual channel memory architecture
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (with AMD Ryzen CPU); x8 mode (with AMD 7th Generation A-series/Athlon CPU)) , 2 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 1 x USB-C Gen1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x VGA , 1 x DVI-D , 1 x HDMI , 3 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
AMD CrossFireX technology support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, Nahimic 2 Sound Technology
Software Included
RAMdisk, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
WHQL
30.4 cm
24.3 cm
