Fully Controllable Fan Headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
Extreme Storage Performance: Turbo M.2
Enjoy a blazing fast system boot up and insanely quick loading of applications and data. Delivering speeds up to 32Gb/s per device using Gen3 x4, Turbo M.2 is over 5 times faster than a regular SATA III connection!
X-Boost Your Storage Performance
When enabled, X-Boost auto-detects and optimizes your SSDs to keep your system fast and maximize storage performance, making sure you reach the battlefield even quicker or saving you a lot of time when transferring data.
Intel Optane™ Ready
This new technological marvel brings game-changing performance to memory and storage devices. Allow Optane™ caching to boost your storage devices for an even faster gaming system!
Stay cool
Cooling your PC is essential for reliable performance. MSI has made sure to add enough fan headers with full control to allow you to cool your system to the max. -
Enjoy the advanced video standards
Supporting the display connectors for advanced technologies (OLED, HDR) and legacy connectors for beamers, MSI motherboards are designed to make life easier for any professional user. -
Professional sound quality
Get the immersive sound experience. MSI Audio Boost delivers the high sound quality through the use of premium-quality audio components. This lets you enjoy breathtaking, game-changing sound to create the dynamic soundscapes. -
Be the first to boot up in the morning
This MSI product supports all the storage standards. This allows you to connect any ultra-fast storage device, giving you noticeable benefits. Start programs faster, load data faster and increase productivity. -
Stable, secure and fast networking
Optimized for professional and multimedia use, this motherboard comes equipped with a high-quality network solution ready to serve you with 24/7 reliability when transferring big data. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your system's memory with more speed, higher overclockability and increased stability. -
Designed for limitless tuning
Founded on experience and with a long history of creating the motherboards, packed with smart features, you can count on this motherboard to deliver the optimal performance under the extreme conditions. Countless system tuning and troubleshooting tools are at your disposal to push your system to another heights and satisfy even the demanding tweaker. -
Built on everlasting quality
Using only the fine-quality components and integrating the technological innovations deliver the improved professional experience. High quality under the extreme conditions ensures a super-reliable, long lasting and high-performance motherboard.
- MSI B250M PRO-VDH - motherboard - micro ATX - LGA1151 Socket - B250
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel B250
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4
- Storage Ports
- 6 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 1 + 3 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B250
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 3 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x DVI-D , 1 x USB-C Gen1 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x PS/2 keyboard
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x audio - header , 1 x parallel - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- MSI ClickBIOS
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI Steel Armor, MSI Military Class V, Double ESD Protection, Intel Optane Memory Ready
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI M-Cloud, MSI X-BOOST
- 24.4 cm
- 22.8 cm
