Memory boost
Give your memory a performance boost. -
EZ debug LED
Easy way to troubleshoot. -
Double ESD protection
Double-layer grounding motherboard mounting holes. -
Click BIOS
Secure and reliable UEFI BIOS solution.
- MSI B250I PRO - motherboard - mini ITX - LGA1151 Socket - B250
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel B250
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- RAM Supported
- 2 DIMM slots - DDR4
- Storage Ports
- 4 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B250
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Technology
- DDR4
- Bus Clock
- 2400 MHz
- Dual channel memory architecture
Audio
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- MSI ClickBIOS
- Hardware Features
- MSI Military Class IV, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI Steel Armor, Double ESD Protection, Intel Optane Memory Ready
- Software Included
- MSI X-BOOST
MSI B250I PRO LGA1151 Intel B250 DDR4 mITX
