MSI B250 PC MATE LGA1151 Intel B250 DDR4 ATX
Quicklinx: CLNZWS00 Mfr#: B250 PC MATE
Fully Controllable Fan Headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
Multi GPU Support
Professionals and enthusiasts strive for the best performance to make their systems faster. MSI motherboards fully support multi GPU technologies. Optimal PCI slot placement allows for the best fit and usage conditions to ensure the best thermal conditions.
Extreme Storage Performance: 2X Turbo M.2
Enjoy a blazing fast system boot up and insanely quick loading of applications and data. Delivering speeds up to 32Gb/s per device using Gen3 x4, Turbo M.2 is over 5 times faster than a regular SATA III connection! You can even mix up devices and set up RAID easily using M.2 Genie, for even better performance.
X-Boost Your Storage Performance
When enabled, X-Boost auto-detects and optimizes your SSDs to keep your system fast and maximize storage performance, making sure you reach the battlefield even quicker or saving you a lot of time when transferring data.
Intel Optane™ Ready
This new technological marvel brings game-changing performance to memory and storage devices. Allow Optane™ caching to boost your storage devices for an even faster gaming system!
  • Stay cool
    Cooling your PC is essential for reliable performance. MSI has made sure to add enough fan headers with full control to allow you to cool your system to the max.
  • Enjoy the advanced video standards
    Supporting the display connectors for advanced technologies (OLED, HDR) and legacy connectors for beamers, MSI motherboards are designed to make life easier for any professional user.
  • Professional sound quality
    Get the immersive sound experience. MSI Audio Boost delivers the high sound quality through the use of premium-quality audio components. This lets you enjoy breathtaking, game-changing sound to create the dynamic soundscapes.
  • Be the first to boot up in the morning
    This MSI product supports all the storage standards. This allows you to connect any ultra-fast storage device, giving you noticeable benefits. Start programs faster, load data faster and increase productivity.
  • Stable, secure and fast networking
    Optimized for professional and multimedia use, this motherboard comes equipped with a high-quality network solution ready to serve you with 24/7 reliability when transferring big data.
  • Unmatched memory performance
    MSI motherboards are crammed with features to fuel your system's memory with more speed, higher overclockability and increased stability.
  • Designed for limitless tuning
    Founded on experience and with a long history of creating the motherboards, packed with smart features, you can count on this motherboard to deliver the optimal performance under the extreme conditions. Countless system tuning and troubleshooting tools are at your disposal to push your system to another heights and satisfy even the demanding tweaker.
  • Built on everlasting quality
    Using only the fine-quality components and integrating the technological innovations deliver the improved professional experience. High quality under the extreme conditions ensures a super-reliable, long lasting and high-performance motherboard.
MSI B250 PC MATE - motherboard - ATX - LGA1151 Socket - B250
Motherboard - ATX
Chipset Type
Intel B250 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4
Storage Ports
6 x SATA-600, 2 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel B250 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x4 mode) , 3 x PCIe 3.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x VGA , 1 x audio line-in - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x audio - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS
Hardware Features
Intel Extreme Memory Profile (XMP) support, AMD CrossFireX technology support, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI Steel Armor, MSI Military Class V, Double ESD Protection, Intel Optane Memory Ready
Software Included
MSI Command Center, RAMdisk, MSI Live Update 6, MSI M-Cloud, MSI X-BOOST
30.4 cm
24.3 cm
