Making your life easier is our business
The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
SPECIFICATIONS
Supports 6th Gen Intel® Core™ / Pentium® / Celeron® processors
CPU socket LGA 1151
Intel® B150 Chipset
Graphics Interface - 1 x PCI-E 3.0 x16
Display interface - HDMI, DVI – Requires Processor Graphics
Memory support - 4 DIMMs, Dual Channel DDR4-2133 MHz
Expansion slots - 2 x PCI-E x1
SATA - 6 * SATA 6 Gb/s (2 x ports from SATA Express port)
USB - 6 x USB 3.1 Gen1, 6 x USB 2.0
LAN - Realtek® Gigabit Ethernet
Audio - 8-channel(7.1) HD Audio with Audio Boost
Unmatched memory performance and stability
With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability. -
Fast storage with SATA Express
SATA Express offers a solution in high speed storage through PCI-Express, providing more bandwidth for the generation SSDs up to 16 Gb/s. -
The award-winning CLICK BIOS 5
Explore the greatly improved, award-winning CLICK BIOS 5 and use it to tune your system to maximum performance. MSI CLICK BIOS 5 is the next generation UEFI BIOS with optimizations for Windows 10. -
Easy diagnostic
MSI EZ debug LED is an easy troubleshooting tool using 3 LEDs to indicate CPU/Memory/VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the source of your problem and get back into operation quickly. -
Enhanced CPU overvoltage protection
Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. A red LED near the 24 pin CPU power connector let you know that overvoltage protection is activated for easier troubleshooting. -
VGA Armor: reinforced PCI Express slot
With the increased size and weight of modern high end graphics cards, traditional PCI Express slots often show signs of bending or even breaking. Meet VGA Armor, strengthened PCI Express slots using more solder points to make sure you never have to worry about breaking off any of the slots. -
Total fan control
Total fan control gives you complete control of all your fans connected to the motherboard, through a revolutionary and easy to use interface. -
Studio grade sound with Audio Boost
With Audio Boost we're delivering the highest sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 6-channel audio or high impendence headphones and truly dominate the game. -
2x front USB 3.1 Gen1
With a clever placed USB 3.1 Gen1 front pin header, available on MSI motherboards, you can connect up to 2 USB 3.1 Gen1 devices directly to the front of your PC chassis. This way you can easily enjoy fast USB speeds without having to use the hard-to-reach USB ports on the rear. -
Legacy DVI video support
To support professional monitors, TV's, beamers and other displays, this MSI motherboard features DVI video output. No matter what screen type you want to connect, using a dedicated graphics card or an onboard connector, MSI motherboards have you covered.
- MSI B150M PRO-DH - motherboard - micro ATX - LGA1151 Socket - B150
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, ECC, unbuffered
- Storage Ports
- 6 x SATA-600, 1 x SATA Express port
- USB / FireWire Ports
- 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x SATA Express port
- 1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 4 x USB 3.1 Gen 1 , 1 x PS/2 mouse
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- UEFI BIOS, MSI ClickBIOS 5
- Hardware Features
- Intel Small Business Advantage support, MSI Military Class IV, 4K Ultra HD ready, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI VGA Armor, overvoltage protection
- Software Included
- MSI M-Cloud
- 23.5 cm
- 22.8 cm
