MSI ATI Radeon 7770 HD 1020MHz 1GB PCI-Express 3.0 HDMI OC
Quicklinx: 7YWDWS00 Mfr#: R7770-2PMD1GD5/OC
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Core/Memory
  • 1020MHz Core
  • 1024MB GDDR5 4500MHz Memory
Video Output Function
  • Dual-link DVI x 1
  • Mini DisplayPort x 2
  • HDMI x 1
Key Features
MSI Afterburner overclocking utility
  • Supports overvoltage function
  • Supports advanced fan speed control.
  • Supports burn-in stability test.
Dual Fan Thermal Design
  • Produces more airflow than traditional single fan thermal design.
  • Provides better heat dissipation with huge heatsink.
AMD GHz Edition
  • World's First graphics card with default 1 GHz core clock.
  • Provides better performance and visual experience.
AMD Eyefinity Technology Support
  • AMD Eyefinity Technology supports maximum 6 displays with 2 DisplayPorts via Multi-Stream Transport (MST HUB).
Specification
  • Graphics Engine ATI Radeon HD 7770
  • Interface PCI Express x16 3.0
  • Memory Type GDDR5
  • Memory Size(MB) 1024
  • Memory Interface 128 bits
  • Core Clock Speed(MHz) 1020
  • Memory Clock Speed(MHz) 4500
  • DVI Output 1
  • HDMI-Output 1
  • Mini DisplayPort 2
  • HDCP Support Y
  • HDMI Support Y
  • Dual-link DVI Y
  • Display Output (Max Resolution) 2560x1600
  • RAMDACs 400
  • DirectX Version Support 11
  • OpenGL Version Support 4.2
  • CrossFire Support Y
  • Card Dimension(mm) 235 x 111 x 38mm
  • HDMI + DVI output
    HDMI and DVI are the comprehensive used interfaces for high definition video display. MSI adopts two interfaces to provide a complete output solution for users to enjoy the latest HD video such as Blu-ray movie.
  • HDMI support
    MSI graphics card offers the HDMI functionality to provide access to premium digital content. HDMI enables gaming enthusiasts to seamlessly connect to their LCD monitor to bring the ultimate multimedia experience.
  • Afterburner
    This utility enables MSI graphics card users to boost performance and to monitor all kinds of critical information in real-time.
  • MSI solid capacitor graphic card
    For the gamers and high-end users, this feature not only means that product has better quality components within, but also provide much stronger support while users want to engage in hard-core tuning.
  • Blu-ray and HD DVD support
    Both support the Blu-ray and HD DVD (High Definition DVD). It comes with the GPU and DDR III superior processing performance in which users can easily enjoy the high-definition video of 1920 x 1080 (1080p/i).
  • HDCP support
    The HDCP provides a robust, cost-effective and transparent method for transmitting and receiving digital entertainment similar to DVI/HDMI-compliant digital displays. HDCP encrypts the date transmitted between the DVI/HDMI connector on the graphics adapter and the display.
  • AMD HD3D
    AMD HD3D technology is supported by an advanced and open ecosystem that, in conjunction with specific AMD hardware and software technologies, enables 3D display capabilities for many PC applications and experiences.
  • AMD stream
    Perform tasks on a PC faster with AMD Stream technology, speed up demanding everyday applications and get more done in less time.
  • HDMI convertible output
    Dual-link DVI convertible output supports video signal through DVI to HDMI interface, which drivers resolution of a digital display up to 1920 x 1200 or higher.
Graphics Processor Manufacturer
AMD
Graphics Processor
AMD Radeon HD 7770
PCI Express 3.0 x16
Memory Size
1 GB
Digital Output
Digital Visual Interface (DVI), DisplayPort, High-Definition Multimedia Interface (HDMI)
Core Clock
1020 MHz
