The advanced GCN architecture is engineered for gamers, who play anything from the MOBA's to the popular AAA titles. Asynchronous shaders and an enhanced geometry engine power another levels of smooth gameplay performance. Experience the next level of immersion with the world of VR gaming and entertainment with Radeon RX graphics cards, powered by the excellent architecture. Puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any frame rate. Enhanced contrast and colors deliver a strikingly sharp, colorful, and vivid visual experience.
                Torx 2.0 fanJust like in games, the exclusive MSI Torx 2.0 fan technology uses the power of teamwork to allow the Twin Frozr VI to achieve another levels of cool. Torx 2.0 fan design generates more air pressure for supremely silent performance in the heat of battle.
                ZeroFrozr - stay undetectedZeroFrozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
                Improved heatsinkLurking under the cover of the gaming graphics card is an engineering masterpiece, designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool and quiet gaming experience.
                Quality backplateA powerful graphics card needs a strong build to harness its performance. MSI gaming X graphics cards are fitted with a solid metal back plate to make it extra tough. The matte finish completes the Twin Frozr VI design to perfection.
                Multi GPUGaming enthusiasts are always looking for more performance to get the ultimate experience. Using multiple graphics cards in SLI or Crossfire is a great way to find out just how good it gets. MSI gaming graphics cards fully support multi GPU technologies.
- MSI RX 580 GAMING X 8G - graphics card - Radeon RX 580 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 580 - up to
- Memory
- 8 GB GDDR5
- Core Clock
- 1393 MHz
- Stream Processors
- 2304
- Effective Memory Clock
- 8.1 GHz
- Memory Interface
- 256-bit
- Max Monitors Supported
- 5
- Interfaces Details
- 2 x HDMI , 2 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 4.2 cm x 27.6 cm x 14 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 580
- Core Clock
- 1393 MHz
- Stream Processors
- 2304
- VR Ready
- 5
- API Supported
- MSI Solid Capacitor, AMD CrossFireX Technology, Graphics Core Next (GCN), MSI Gaming App, 8 Phase PWM Design, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, FreeSync Technology, MSI Zero Frozr technology, AMD VR Ready Premium, Torx 2.0 Fans, Twin Frozr VI Thermal Design, HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.1 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- MSI Afterburner, XSplit Gamecaster 2, WTFast Gamers Private Network (2 months Premium licence), XSplit Broadcaster 2
- 4.2 cm
- 27.6 cm
- 14 cm
- 978 g
