MSI AMD Radeon R7 250 1050MHz 2GB GDDR3 PCI-Express 3.0 HDMI OC (R7 250 2GD3/OC)
Quicklinx: 916TWS00 Mfr#: R7250-2GD3/OC
  • AMD Radeon R7 250
  • High-Definition Multimedia Interface (HDMI)
It's the beginning of a new era. Radeon™ is gaming. Ultra Resolution Gaming
GPUs built for the demands of ultra-high resolution gaming in single and multi-display configurations: get the most out of every square inch of screen.
Propeller Blade Technology
  • MSI's exclusive Propeller Blade Technology - 20% more airflow - 50% Larger Cooling Area
  • large 10cm fan
All Solid Capacitors
  • 10 years ultra-long liftime (under full load)
  • Lower temperature and high efficiency
  • Extreme low ESR
MSI Afterburner Overclocking Utility
  • Advanced fan speed control functions
  • In-game video recording
  • iOS/Android remote control
  • Built-in DX11.2 benchmark
AMD HD3D technology
  • Stereoscopic 3D display/glasses and Blu-ray 3D support
  • Stereoscopic 3D gaming Support
  • 3rd part Stereoscopic 3D middleware software support
MSI R7 250 2GD3 OC - graphics card - Radeon R7 250 - 2 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 250
2 GB DDR3
Core Clock
1050 MHz
Boost Clock
1100 MHz
Stream Processors
384
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
DVI-D (Single-Link) , HDMI , VGA
API Supported
OpenGL 4.3, DirectX 11.2
3.5 cm x 11.1 cm x 10.8 cm
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 250
Core Clock
1050 MHz
Boost Clock
1100 MHz
Stream Processors
384
API Supported
MSI Solid Capacitor, AMD Eyefinity Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, Propeller Blade Technology, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
48 Watt
Software Included
Drivers & Utilities, MSI Afterburner
3.5 cm
11.1 cm
10.8 cm
