MSI A88XM-E35 AMD FM2+ A88X DDR3 mATX
Quicklinx: 95PKWS00 Mfr#: A88XM-E35
When combined with today's processors featuring advanced integrated graphics, MSI motherboard equippeds with 3 video outputs support 4K monitors and triple display configurations for more efficiency and flexibility of the desktop layout or immersive display of movies and games.
Compared to common motherboard which need extra BIOS chips, MSI's M-Flash has a double advantage which doesn't need extra components and secondly, all your BIOS data will be saved in the USB drive. The stored data does not only have backup and upgrade function, moreover, it can also be seen as a portable BIOS chip which is actually able to boot up your PC.
  • Military Class 4
    MSI's Military Class 4 components support you while you are questing, racing, battling and shooting your way to the top. MSI's Military Class 4 components deliver record-breaking stability when you need to keep cool in the heat of battle. The standard in stability built on a proven technology of high quality components.
  • Military Class essentials
    The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit.
  • OC Genie 4
    OC Genie 4 supercharges your speed experience! When used, OC Genie 4 accelerates your entire system and puts it into overdrive! Tuned by the professional overclockers, OC Genie 4 hands you record-breaking performance on a silver plate.
  • Click BIOS 4
    The MSI Click BIOS 4 is the UEFI BIOS with optimizations for Windows 8. Not only reacting faster and running smoother, it also has better mouse support. This is all comes with many cool features, such as Hardware Monitor, Board Explorer, and OC Profile Preview.
  • PCI Express Gen 3
    With ultra-high 32 Gbps transfer bandwidth, PCI Express Gen 3 provides a 2x faster transfer rate than the previous generation, this delivers amazing capabilities for true next generation extreme gaming.
  • Super charger
    Mobile consumer appliances are getting more and more attention in current day fast moving life style, with smart phones and tablets almost becoming a fashion accessory. However, many ordinary personal computers cannot charge some of these devices, making it difficult to stay connected. The MSI super charger is a Windows resident program capable of revising the power supply mode of your USB port to become more powerful. Once your phone or tablet is connected to your USB port, the super charger sends a signal to initiate its charging circuit, making it a really smart and convenient charging solution for mobile computing needs.
  • USB 3.0
    Compared to the 480 Mbps provided by traditional USB 2.0, the USB 3.0's 5 Gbps offers 10 times the transfer bandwidth, so transferring a Blu-ray movie takes less than one minute.
  • SATA 6 Gbps
    SATA 6 Gbps provides double the bandwidth of traditional SATA 3 Gbps, and increases the data transfer rate between your motherboard and internal storage devices, such as 7200 RPM HDDs, 10000 RPM HDDs and SSDs. It's also the current trend for upcoming high-speed internal storage devices to break the existing bottleneck of a PC's performance.
  • 3 display outputs
  • Fast boot
    No more waiting for entering O/S! MSI fast boot helps to make motherboards boot lightning fast. MSI also adds the GO2BIOS button with-in, simply click it to reset your PC and then go straight to the system BIOS.
  • M-Flash
  • USB safeguard
    USB safeguard can prevent motherboards and USB devices from being damaged by short-circuit and ESD (Electro-Static Discharge) with Anti-ESD chips built-into the motherboards. Additionally, the safeguard can protect against such dangers multiple times, and greatly improves product lifespan.
  • Winki 3
    Winki 3 is a free Linux-based O/S which is based on the Linux core. With an ultra-fast booting speed and a multi-language interface, the built-in Winki 3 provides an easy-to-use Internet environment that includes the most popular functions such as Internet surfing, web mail, instant messaging, picture browsing, and more. It's the most practical way to be online in the shortest time.
  • Cool'n'Quiet technology
    AMD Cool'n'Quiet technology reduces heat and noise so you can experience amazing performance without distraction. Combined with core enhancements, included in the AMD processors, that can improve overall power savings, deliver better multitasking and energy efficiency. Cool'n'Quiet technology can automatically adjust processor ratio to throttle CPU speed with four modes.
MSI A88XM-E35 - motherboard - micro ATX - Socket FM2+ - AMD A88X
Motherboard - micro ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Athlon, A series
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x HDMI , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x parallel - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, jack retasking, USB Safeguard, Intel Extreme Memory Profile (XMP) support, MSI Winki 3, Super Charger, AMD Radeon Dual Graphics, AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, Clear CMOS Button
Software Included
Drivers & Utilities, MSI Live Update 5
22.6 cm
21.6 cm
