- Supports AMD FX / Phenom™ II / Athlon™ II / Sempron™ processors for AM3+ socket
- Supports DDR3-2133(OC) Memory
- USB 3.1: Delivering speeds up to 10Gb/s, USB 3.1 offers performance twice as fast as a regular USB 3.0 connection
- USB 3.1 + SATA 6Gb/s
- Military Class 4: Top Quality & Stability
- OC Genie 4: Overclock in 1 Second
- Click BIOS 4: Easily Fine-tune Your System
- Multi-GPU: NVIDIA SLI & AMD CrossFire Support
- Command Center: Control & Customize Your PC Settings
- Fast Boot: Quickly Boot Up & Enter OS in A Few Seconds
- M-Flash: Simply Update & Backup Your BIOS
- Live Update 6: Easily Update The Latest BIOS & Drivers
Optimized for multiple graphics cards
MSI motherboards feature one or more PCI Express 3.0 slots, perfectly aligned and with enough space for an optimal airflow when using multiple graphics cards. That way, you will never have to worry about an overheating PC, while you are enjoying the best graphics jumping off from your monitor when running Nvidia® SLI™ or AMD CrossFire™ gaming setup
Meet the new speed king
USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATAIII! Transferring your favorite games, music and movies over USB has never been faster.
- 20X faster than USB 2.0
- 2x faster than USB 3.0
- Up to 10Gbps data transfer bandwidth
- Boost transfer rate between your PC and external storage devices
ISOLATED AUDIO PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Acting like a dedicated soundcard by physically isolating the audio circuitry which is separated by a isolating path. Less interference gives you a more clear audio signal.
OC Genie 4
With the one-second overclocking option OC Genie we're giving you even more performance. Just hit the button and your PC gets another adrenalin shot straight away. Give your system an awesome performance boost with ease.
CLICK BIOS 4
The MSI Click BIOS 4 is the latest UEFI BIOS with optimizations for Windows 8. Not only that it also reacts faster, runs smoother and has better mouse support. And this all comes with many cool features. Click on the button on the right to visit our dedicated BIOS page and learn more.
MSI USB 3.1
USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATAIII! Transferring your favorite games, music and movies over USB has never been faster. -
Get up to 2 PCI-Express 2.0 x16 slots, with optimal placement for better fitting and airflow. That way, you can enjoy the best graphics at the highest framerate jumping off from your screen when running a NVIDIA SLI or AMD CrossFire gaming setup. -
Military class 4
Military Class 4 is the next step in high quality components. The Dark Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions. -
Dark choke
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability. -
Dark cap
With their aluminum core design, Dark CAP's has been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan. -
Isolated audio PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Acting like a dedicated soundcard by physically isolating the audio circuitry which is separated by a isolating path. Less interference gives you a more clear audio signal. -
High quality audio capacitors
With the use of professional Nichicon Japanese capacitors, specially designed for audio purposes, 970A SLI Krait Edition delivers high fidelity crystal clear sound with exceptional acoustics and realism. -
OC Genie 4
With the one-second overclocking option OC Genie you get even more performance. Just hit the button and your PC gets another adrenalin shot straight away. Give your system an awesome performance boost with ease. -
Unlimited RAMdisk
MSI Command Center integrates an unlimited RAMdisk. With a RAMdisk you can create a virtual drive from your system memory enabling speeds 20x faster than a modern SSD. -
Fast boot
No more seamless waiting for your O/S to be loaded! MSI Fast Boot helps to make your system boot lightning fast. MSI Fast Boot also features a GO2BIOS button. Simply click it to restart your PC and go straight to the system BIOS. -
M-Flash
Compared to common motherboards which need extra BIOS chips, MSI's M-Flash has a double advantage which doesn't need extra components and secondly, all your BIOS data will be saved in the USB drive. The stored data does not only have backup and upgrade function, moreover, it can also be seen as a portable BIOS chip which is actually able to boot up your PC.
- MSI 970A SLI - Krait Edition - motherboard - ATX - Socket AM3+ - AMD 970
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD 970 / AMD SB950
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Sempron, Athlon II, Phenom II, FX
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3
- Storage Ports
- 6 x SATA-600 (RAID)
- USB / FireWire Ports
- 2 x USB 3.1 + 6 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz (O.C.)
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111E
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 (x8 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.1 , 6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 1 x audio - header , 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, M-Flash, UEFI BIOS, MSI ClickBIOS 4
- Hardware Features
- NVIDIA 2-way SLI Technology Support, AMD CrossFireX technology support, MSI Military Class IV, OC Genie 4, MSI Fast Boot, Clear CMOS Button
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6
- Plug and Play
- 30.5 cm
- 24.4 cm
