Motorola VM855 Smart Connect Wi-Fi Video Baby Monitor
Quicklinx: HRBYWS00 Mfr#: VM855
Motorola VM855 Connect includes a 5" screen and a portable, battery-powered camera with remote pan, tilt and zoom and night vision that connects to the Motorola Nursery app to enable HD (720p) video to stay connected to what's going on at home. Take the camera with you around the home to watch your little one wherever they are.
  • Crib mount
    This baby monitor comes with a flexible crib mount, giving you almost unlimited options for camera placement. With this mount, you can easily position the detachable camera at any angle you like.
  • Detachable camera
    The camera of the VM855 baby monitor is removable and can therefore be used anywhere in the house. You can easily charge the VM855 for up to 3 hours without the need for cables or wires afterwards.
  • Night vision
    Is it night or do you have poor lighting conditions? That's no problem for the Motorola Nursery VM855 baby monitor. The camera has built-in night vision so you can see your baby in the dark.
Motorola VM855 Connect - baby monitoring system - wireless (Wi-Fi, 2.4GHz radio)
System
Baby monitoring system - wireless - Wi-Fi, 2.4GHz radio
Monitor
5" - colour
Camera
1 cameras - indoor - night vision
12.7 cm x 22.9 cm x 16.5 cm
810 g
2 years
System
Network Interface
Wi-Fi, 2.4GHz radio
Temperature sensor, sound alerts, built-in battery, FHSS transmission, motion detection, sound detection, two-way audio support, 720p HD video, 2x digital zoom
Package Content
Monitor, camera (pan & tilt)
Warranty
2 years
Monitor
Diagonal Size
5"
Image Resolution
480x272
Cameras
Quantity
1 cameras
Camera Type
Indoor
Night Vision
12.7 cm
22.9 cm
16.5 cm
810 g
Details
Camera: 9.5 cm x 9.5 cm x 12 cm - 240 g , Monitor: 9.5 cm x 15.8 cm x 2.3 cm - 220 g
